Interior/Exterior R53 gauge pod installation problems
Old Jan 31, 2009 | 07:35 PM
albehere's Avatar
albehere
Hi All,
I have just installed the factory gauge pod on the steering column. The toggle switches do not work when I plug in the new wiring harness but the gauges do. If I squeeze the harness tight, I can get the drivers window to work, but that's all. If I plug in the original harness back in, the toggles work again. Has any one seen this happen before?
Old Feb 1, 2009 | 02:07 AM
Fatherdeth's Avatar
Fatherdeth
Not too sure about this application, but my guess would be maybe some bent pins. Look down in the connector and make sure there aren't any pins bent. When you connect harnesses always be very careful when pushing them together and make sure they are lined up correctly.
Old Feb 1, 2009 | 02:55 PM
albehere's Avatar
albehere
Thanks for the answer. I tried it again today and everything seems to work. Maybe the pins did not line up last night.
Old Feb 1, 2009 | 11:07 PM
Fatherdeth's Avatar
Fatherdeth
Glad everything worked out for you.
iggi
18
Feb 9, 2026 01:00 AM
silence2-38554
98
Sep 21, 2016 02:52 PM
squawSkiBum
Oct 2, 2015 09:21 AM
