Interior/Exterior JCW CF brake handle
Old Oct 4, 2008 | 08:10 AM
JCWMINIMIAMI's Avatar
JCWMINIMIAMI
JCW CF brake handle
I am having a hard time installing...I have my stock removed but have no idea how to keep it in place.....can anyone help?
Old Oct 4, 2008 | 10:16 AM
froggy's Avatar
froggy
You can either glue it (I believe that's how the dealer would do it), but I didn't like that idea. So, I just wrapped the metal handle with some electrical tape to provide the necessary grip. It took a few tries to get the exact thickness right, and my ebrake handle is not totally rigidly fixed on. I can rotate the handle if I try hard enough, but I think it's fine.
Old Oct 8, 2008 | 05:35 AM
RaceTripper's Avatar
RaceTripper
I used silicone adhesive. The handle gives a little, but can be removed easily enough if necessary.
Old Oct 17, 2008 | 06:51 AM
FortyTwo's Avatar
FortyTwo
The standards seem to be to glue it, and a lot of people use tape and friction to hold it. I used set screws to keep my e-brake secure... if you're interested, I wrote down the process. Good luck!
http://coopermods.com/archives/7
Old Jun 13, 2009 | 12:27 PM
bonehead04's Avatar
bonehead04
Can anyone elaborate on the clips used to hold the original handle on the lever? I can't for the life of me remove the OEM handle.
Old Jun 13, 2009 | 02:02 PM
Robin Casady's Avatar
Robin Casady
This page might help.
Old Jun 13, 2009 | 02:17 PM
bonehead04's Avatar
bonehead04
Thanks. I sorta figured it out. That silver cap near the button does NOT just 'gently jiggle' off as has been described. Levered with a screw driver and ended up breaking the tabs that hold it on. All done now. Irksome that the JCW handle does not 'lock' on. Used the electrical tape method, but if it ends up rotating and coming loose, I may have to hunker down and create a set screw.
Old Jun 13, 2009 | 02:43 PM
bonehead04's Avatar
bonehead04
The alcantara boot got a loose at the front end. Will have to find some Krazy Glue and redo it.
theblackfalcon
Oct 11, 2015 09:49 AM
nomar116
Aug 10, 2015 11:24 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
