Interior/Exterior chrome inserts
chrome inserts
ok so I am going to throw this question out there...
See the black trim around the fog lights on the aero bumper.
Does anyone know if they make a chrome insert that fits in the area. I ordered the decals that fit there and don't like the way they look. I was hoping someone out there may have run across the item I am looking for .
thanks in advance
( thank you goes to mmatarella for the use of your pic) your car is awesome
thanks in advance
I've seen them in white(actually had them on mine at one time) and black but not chrome.A/C or Vinyl Styles could possibly make you some out of chrome vinyl material if that would work for you.
Bill
Bill
hey
Hey Bill
Yah I ordered chrome stickers from A/Creations
I was not thrilled with the stickers, the one side tore as I was putting it on.
Are the inserts your referring to stickers or hard plastic ?
I want something other then a sticker.
Yes, you are correct,stickers and they are at least in my case a PITA to install,and easy to tear.There is however some heavy,not sure of MIL thickness, vinyl out there that could be used for this.I would think that either A/C or Lyle @Vinyl Styles would be able to help even though maybe costly if a one off deal.Even if you had one of the A/C stickers,you possibly take it to a graffics/vinyl decal/sign shop and have them duplicate it in heavier materal.Does that sound like a feesible idea?
You can get an OEM part from MINI made of hard plastic that is adhesive backed and fits perfectly around the fogs (as seen in your pic above). I think they are about $50 /pair. You could probably paint them any color you like or cover them with vinyl before installing.
Big Daddy
I new MINI had chrome surrounds for fog lights.
I was not aware MINI had the same part for the Aero grill inserts.
I will check with them and let you all know.
MINI/BMW calls them "fog lamp covers" and the part no. for the aero bumper is 51110151570. Here's the only current pic I have of my car with the part installed. Hope this helps.
Interior/Exterior Chrome strip above license plate, who makes black ?
got_mini?
Oct 7, 2015 02:12 PM
Oct 1, 2015 12:34 PM
Oct 1, 2015 12:28 PM
Oct 1, 2015 12:13 PM
