Interior/Exterior How do you remove this??
Old Aug 10, 2008 | 01:24 PM
juchong's Avatar
juchong
Can anyone help me remove this trim piece? I'm trying to get it off so I can run speaker wires through the trim and under the seat. Here are some pictures of what i'm taking about:
Thanks!
Old Aug 10, 2008 | 01:36 PM
matty125's Avatar
matty125
check out "realoem.com" they might have the diagram you need
Old Aug 10, 2008 | 02:43 PM
SNEEEZY - Erika's Avatar
SNEEEZY - Erika
Rattle Can Queen!!!
Remove the rubber seal completely.
There will be several clips (7, I think!) that you will need to pop out.
However, since you are wanting to simply tuck the speaker wire into the space behind this piece, you should be able to use a flathead screwdriver wrapped in tape as a wedge to gently lift back the trim a small section at a time.
Removing the trim piece was easy, but getting it all back together was a pain!
I remove mine completely because I decided to change the color from gray to black as part of my interior makeover.
Old Aug 10, 2008 | 02:55 PM
juchong's Avatar
juchong
Alright, I'm looking at the diagram, but it doesn't say much...
http://www.realoem.com/bmw/showparts...39&hg=51&fg=55
Anyone have some experience removing this?
Edit: Is it possible to get under the carpet if I remove that piece? Also, thanks for the reply Uber!
Old Aug 11, 2008 | 12:49 PM
amazingrando's Avatar
amazingrando
Auto on Sport Button guy
I removed mine completely about a year ago. It's really not all that difficult to do. You just need to pull on it to get the plastic clips to come loose. As mentioned already It's a little more work to put it back together. I also found that I had to removed my seat belt bolt, it's a torx bolt, but I don't remember what size.
Old Aug 11, 2008 | 12:53 PM
juchong's Avatar
juchong
Its a T40 bolt. And as stated, all you have to do is pry it off. Hope this helps someone!!
UncDeo
Nov 4, 2019 04:08 AM
BRracing
Oct 24, 2015 10:07 PM
Sep 2, 2015 11:15 AM
Sep 2, 2015 09:05 AM
broncobuddha
Sep 1, 2015 06:32 PM
