Interior/Exterior Removing Grill Trim
just pull for the lower grill trim, its hel in by clips that snap into place.
the top trim has 2 or 3 screws and a bunch of clips. take a flat head screw driver and push the clips till they pop off (when you see the clips it will make sense)
its really easy...
its really easy...
I recently replaced the chrome trim moulding with black trim moulding around the grille of my '08 MCSa.The lower grille section is held in with I believe 4 clips,just pull out one side first then you can press in the other clips to completely remove it.The hood moulding is held on by 4 screws (2 outer,2 inner) and 6 clips.Use a needle nose pliers to release the clips.
It is fairly easy to do.
for the grill trim it's absolutely not an issue
I just tried to install the JCW grille on my R55S and it didn't fit, am i right in thinking that the regular (non S) cooper and the S have different size grilles? Did i buy the wrong grille (51 11 0 404 122)?
There's a little walkthrough with pictures and instruction here.
Very easy to do.
http://www.takeforum.com/size/viewto...96&mforum=size
Very easy to do.
Interior/Exterior Need Help With Exterior Decisions (05' MCS PHM/W)
boostedhaze
Jan 2, 2018 07:26 PM
