Interior/Exterior Rain gutter trim
Old Jun 20, 2008 | 03:04 PM
camdjkim's Avatar
camdjkim
Rain gutter trim
Don't know what it's called. The black plastic trim that keeps water from rolling off the roof and into the car.
I had my bike roof rack with bike and drove into my garage . The bike was fine, but the rack was ripped off the roof and took the black trim with it. How do i replace it? Is it something I can do without any special tools? Anybody know what it's called? I have a 04 Mini S
Old Jun 20, 2008 | 03:11 PM
andrewholmes's Avatar
andrewholmes
not sure
i dont know if this helps but if your local mini dealership has any sort of decent parts guy he will be able to give you a price on a new one. i have never had mine off but i would guess it is either a pressure fit / clips / or 2 sided automotive tape of some sorts. in any manner it shouldnt be hard to do.
sorry i couldnt be more help but when you figure it out exactly, let us all know how its done
Old Jun 22, 2008 | 05:12 PM
Darkness's Avatar
Darkness
I think it's called trim roof molding or something. I can't remember. Its not obvious in the part book.
To removed/replace:
-open the door and pull the weather stripping (try middle of the door closest to the B pillar) and gently pulled it all the way around the top to the A pilar and a little further
-remove 4 or 5 screws holding it
-pull on the molding (hard) it will bend and be useless afterwards, but you're replacing it anyway. There are pressure clips that hold it above the rear window
-install new one: start my lining the back up and jam the new one in onto the clips above the rear window, continue all the way to the front, snap in the front corner piece (you will have to order a clip for your new molding, i fabricated one from something i already had)
-reinstall screws
-slid weather stripping back into place and make sure it's seated right.
Hope that helps
Old Jun 23, 2008 | 08:06 AM
camdjkim's Avatar
camdjkim
I'll have to try it, Thanks mr Darkness.
Old Mar 11, 2009 | 11:46 PM
ghosthound's Avatar
ghosthound
is it removable and replaceable?
Im considering changing my roof color DIY style.
Old Mar 11, 2009 | 11:50 PM
chaseabryant's Avatar
chaseabryant
This may help: https://www.northamericanmotoring.co...l-removal.html
-Chase
Old Mar 12, 2009 | 01:59 AM
JustJAY's Avatar
JustJAY
Originally Posted by chaseabryant
There you go!. It is easy, just take your time the 1st time. Once you do one side, the other side will be easy and quicker.
Old Mar 22, 2009 | 10:23 PM
edubledie's Avatar
edubledie
had mine replaced before the curved piece over the pillar flew off one day and yeah i know for a fact that MOS sells it for i think it was 90 dollars because its the whole gutter set not just piece by piece
Old Mar 24, 2009 | 08:05 PM
Ubercooper968's Avatar
Ubercooper968
SAME THING HAPPENED TO ME!!! i just bought new ones for about 50 dollars a piece! IT blows
Old Mar 7, 2012 | 05:06 PM
RedBlur's Avatar
RedBlur
not to sound skeptical but i am about to attempt darkness' suggestion for removing and installing the driver side trim. does anyone know if he was correct?
USNAE2
16
Jun 17, 2022 07:17 AM
Doc Pain
Mar 10, 2021 04:50 AM
ian260
Mar 29, 2017 06:08 AM
OutMotoring
Mar 3, 2017 06:29 AM
vulkandino
Oct 31, 2015 08:29 PM
