Interior/Exterior light in the scoop! hehe
Old May 23, 2008 | 10:30 AM
  #26
ImagoX's Avatar
ImagoX
Originally Posted by Bang110
Any issues with the IC heat melting the LED or anything?
Not at all - it doesn't get that hot there because of the air flow through the scoop - it seems to get hottest when the car is STOPPED actually - stick your hand in there, and you'll find that even without air cooling the radiator it's not nearly hot enough to damage the LEDs, let alone affect the silicone coating. I've had another strip mounted to the underside of my M7 strut bar for months and despite being right above the engine those are fine, too...
Old May 23, 2008 | 10:55 AM
  #27
Some Guy's Avatar
Some Guy
I get the Knightrider thing all the time.
I used one of these, it creates these cool little dots that bounce off the paint:http://www.oznium.com/waterproof-led-ribbon
Old May 23, 2008 | 02:17 PM
  #28
Sanbient's Avatar
Sanbient
Here's mine. Recently upgraded my old one to this. More colors/selection whereas old one was just blue.
http://picasaweb.google.com/sanbient...87899222735858 (short clip after install...no daylight photos of it yet.)
San
Edit: Oops..not in scoop. (non-s) Old scanner will be placed in friends scoop though.
Old Jan 19, 2010 | 10:04 AM
  #29
paul_'s Avatar
paul_
How are you guys wiring this up exactly? Power source, switch?
Old Jan 19, 2010 | 10:47 AM
  #30
newbs49's Avatar
newbs49
Haven't seen this thread in a long time.
Old Feb 3, 2010 | 12:49 PM
  #31
Storm180's Avatar
Storm180
I wired it up using a lighted switch in the opening on my parcel tray. Its been a while, but from what I remember, the switch had two power wires (one for constant power to the switch's LED and one going to the scoop's LED) and one ground wire. Beyond that it was a simple splice-the-wires job.
The hardest part of the entire thing was mounting it to the scoop in such a way that you could still get air flow.
Ovrclck
Aug 27, 2015 07:58 PM
cmanlu
R58 :: Coupé Talk (2012+)
Aug 25, 2015 07:35 AM
rentedblackbird
Aug 24, 2015 10:22 AM
O4mcs
Aug 10, 2015 10:22 PM
