Interior/Exterior Angel Eyes Running Lamps
Old Jun 4, 2008 | 09:49 AM
  #51
MLPearson79's Avatar
MLPearson79
Originally Posted by BlimeyCabrio
Hmmm... those look like electroluminescents to me...
I was just reading a thread on another forum about EL angel eyes. It's about a $20 mod if you know what you're doing.
Unfortunately, I don't. I'm going to have to rustle up someone who does, because it actually looks really easy if you know how to wire.
Old Jun 4, 2008 | 04:33 PM
  #52
07BPB's Avatar
07BPB
Originally Posted by 22CooperS
Has anyone had any problems with quality of these lights?? Anyone had one break on them/go out?
I have not had any problems with them. They are made of the same material as the stock lights so they will be as good as them in toughness (i think). And mine haven't blown or gone out. The lights used are LEDs so you will rarely have to change them. Only problem I have is that my current headlights and fogs don't have the same light colour as the halo. Ill probably either by headlights which are more blue in colour, or replace the halo LEDs to true blue LEDs to match my grill neons.
Old Jun 4, 2008 | 04:38 PM
  #53
07BPB's Avatar
07BPB
Or just buy the real ones very very easy mod
Old Jun 4, 2008 | 05:36 PM
  #54
MLPearson79
Yeah but with the ELs I could do the headlamps, parking lamps, driving lights, and fogs, and have it all match...
Old Jun 4, 2008 | 06:37 PM
  #55
BlimeyCabrio's Avatar
BlimeyCabrio
Yeah, I've been thinking about that, too...
Old Jun 4, 2008 | 07:05 PM
  #56
07BPB's Avatar
07BPB
Didnt some one post a picture of a Mustang with that done. How easy is it to do?
Old Jun 4, 2008 | 07:21 PM
  #57
MLPearson79
I was on a Tiburon forum earlier today when I Googled to try and find a DIY. There were some good pictures there. The gist of it is that you buy the EL wire and inverters, bake apart the headlamps (or whichever ones you're going to do, drill a TEENY hole (or two, depending on how thick of a wire you chose and what you're outlining) route the wire through the hole, use a teeny dab of silicone sealant to hold it down, run it back out the other side and out of the lamps to wherever you're going to splice it in, and seal the lamp back up.
It really did not sound hard at all...I just know absolutely zero about wiring. I'm going to have a friend read the DIY later and see how hard he thinks it will be to do the wiring and what we would need. I'm not afraid to do the baking and drilling myself...just unsure about the wiring.
Old Jun 4, 2008 | 07:25 PM
  #58
BlimeyCabrio
Yeah... EL wire is pretty easy to work with. Exactly what Mel said, as I understand it. Wiring is really pretty easy too... you can just tap into one of the parking lamps, and (depending on how much current the inverter draws) either power it directly from there, or wire it to a relay and draw inverter power directly from the battery. Headlamp disassembly / mod / reassembly is by far the part I'd dread the most...
Old Jun 5, 2008 | 06:18 AM
  #59
eager2own's Avatar
eager2own
If you're going to do all that -- may as well knock out a joey mod while you have the headlight assembly taken apart
Old Jun 5, 2008 | 09:19 AM
  #60
#20Works4me's Avatar
#20Works4me
I added halo rings on another car, after two years one burn't out and I didn't like the idea of going back into cracking the headlight casing open again (oven method) to replace it. The rings are not flexible so you would have to get specific size for the Mini headlights, don't know who makes them in our size, also they are glued onto the headlight trim so getting them off again could be a b*&%ch. Would I do it on the Mini.... NOT A CHANCE!, the bumper lights are obviously much easier.
Here's pics of my old Maxima with the halo mod and all accessory lights to match up:
Angel eyes installed with lens cover removed:
Pic taken with flash:
Pic taken without flash ( notice the difference with and without, just brought this up as some had mentioned on how bright they are, but the in the daytime they are almost non existant)
Old Jun 5, 2008 | 02:52 PM
  #61
MLPearson79
That would be removing shiny stuff...and we all know that's never going to happen to my MINI!
Old Jun 20, 2008 | 07:23 PM
  #62
Jason C's Avatar
Jason C
Okay, so I was tired of the blue that my halos where giving off so I swapped them out for these from SuperBrightLEDs.com
Here are the results.
Yes the pics suck but you get the point.
Here is a comparison from the old and the new.
old
new
It may not seem that dramatic in the pics, but it looks alot better in person. Not an exact match but alot better than it was.
Old Jun 24, 2008 | 08:32 AM
  #63
cheweez78's Avatar
cheweez78
much better
Old Jun 24, 2008 | 05:30 PM
  #64
PortMCS's Avatar
PortMCS
I tried installin these a few days ago and i couldnt figure out how to detach the corners of the bumper from the car! I had removed all the bolts and the bumper cover was loose, but i couldnt get at the screws in the splash shileds. It looked as though those are the screws that hold the bumper at the corners? I have the aero bumper so i dont know if its different on the aero. Also, i noticed underneath there are a few rivets holdin the bottom to below the radiator but i dont think i need to remove those to get the lights on ? Can anyone verify this ?
Old Jun 24, 2008 | 05:35 PM
  #65
adbsvc's Avatar
adbsvc
old
new
That looks much better! What is their part# on the ones you bought?
Old Jun 25, 2008 | 07:59 AM
  #66
Jason C's Avatar
Jason C
Thanks. The part number is WLED-WHP. You will need 4 of them to do the swap. It's very easy. They are just held in by rubber grommets that just pull off the back.
Originally Posted by cheweez78
much better
Thanks and welcome to the board.
Old Jul 13, 2008 | 04:43 PM
  #67
bungi's Avatar
bungi
I just picked up a set of these from moss mini, but I'm waiting for the white leds to come in before I install them.
I want to wire these up so that they're on all the time (with ignition power), not just with the parking lights. What would be the nearest power line I could tap to do so? And has anyone else done this?
I have a 98 m3 with angel eyes, and I wired those to be on all the time by tapping into the windshield wiper fluid sensor, which is right next to the headlights. I was thinking I could do something like that.
Old Jul 21, 2008 | 03:58 PM
  #68
tekron's Avatar
tekron
old
new
Do you have LEDS anywhere else on your car? What year is your car and do you experience any flickering or staying on after you turn the car off?
Old Jul 21, 2008 | 10:12 PM
  #69
07BPB's Avatar
07BPB
I have white LEDs in my halo lights, and blue LEDs under the doors, boot, and front foot wells. I only get the front halos flickering for about 10 seconds upon start up and the rear boot light flickers for about 30 seconds until i get driving. Its quite normal.
Old Jul 21, 2008 | 10:53 PM
  #70
Jason C's Avatar
Jason C
Those are the only LEDs I have right now. They do flicker for a few seconds upon start up, but it does not bother me as I'm in the car when I turn them on so I never see them flicker. There is a way to stop the flicker by putting a resistor or something in line with the bulb, but it does not bother me enough to worry about it.
My car is an 04.
Old May 16, 2010 | 12:08 PM
  #71
michele r53's Avatar
michele r53
The MOSS MINI led halos are so so. If you want led halos go to advanced automotive concepts. im getting mine back in the mail on tuesday they did leds on my parking lights as well as my fogs
Old Sep 9, 2010 | 09:45 AM
  #72
dorkfaceandrew's Avatar
dorkfaceandrew
i know this is 1st gen forum, but do you guys know if the moss mini angel eyes will fit onto an R56? or where i can get some?
Getrieben
Sep 12, 2024 07:03 AM
SolCalMini
Aug 29, 2015 07:25 PM
Powershift
Aug 16, 2015 05:14 PM
JamJam43087
Aug 16, 2015 02:02 PM
