Interior/Exterior Angel Eyes Running Lamps
Old Apr 19, 2008 | 04:03 PM
  #26
marco621's Avatar
marco621
Some more halo pics for you guys....
The blue in the halos is definitely more blue than the xenons but oh well, they still look good in my opinion.
Old Apr 19, 2008 | 04:23 PM
  #27
Minian's Avatar
Minian
Great Eyes
Very Easy! If you know how to take off the front bumper cover (BC) it a synch.
Less than 30 minutes. Hell if you're good you can just remove the top front BC screws and the screws just forward of the wheel well lining. The BC will lean forward and you can access/replace the lights. If you own a DS Mini you will want the Stealth Bulbs. I bought a pair as soon as they were on the market.
Minian
Old Apr 19, 2008 | 08:43 PM
  #28
Fatherdeth's Avatar
Fatherdeth
Ok, I finally installed my ebay projector headlights with halo rings today. Guess what? You can change the LEDs out. Basically they have 2 white LEDs on a rubber grommet that plugs into the ring. When the LEDs light up, then the light is transmitted through the ring. I'm going to say that the angel eyes from MOSS could be similar. As I stated before, I have no experience with the MOSS ones, but this is just throwing ideas out to you all.
Old Apr 20, 2008 | 12:58 PM
  #29
MLPearson79's Avatar
MLPearson79
This is how the Hella 2500s are. I was sort of hoping the Moss running lamps might be the same - then you could change out all of the bulbs to make them the same.
On a related note, how was your ebay light install? I've been eyeing those, but I just have the standard headlamps, and don't know if they would plug and play like they are supposed to.
Old Apr 20, 2008 | 01:39 PM
  #30
Capt_bj's Avatar
Capt_bj
did a set
I installed a set of e-bay specials with halo rings. he said the e-bay ad said plug and play but came looking for help when there was a plug....& a set of loose wires hanging out the back of each lite.
not rocket science...but think about it. on std headlights, there's no power to that unit when only parking lites are on if that's when you want the halo to come on. so at a minimum you must figure out the headlight pin out to splice..or run a jumper to the right part of the running/turn lite. depending on how you want 'em to work.
like I said, not rocket science but to do it nice you want to solder things up and use some shrink tape...or crimp some nice connectors. I was also stumped for a bit b4 I discovered the LED part of the circuit was polarity specific. I mean DC across a light bulb equals lite right? not so with LEDs I guess...no LEDs on my 79, and with no wiring diagram I was stumped until I said "I wonder". Not difficult if you've some working knowledge and know how to handle a meter.
I don't know if there's more than one set on e-bay. he bought what he did cuz they were supposed to come with black trim rings...they didn't tho. There was a page with a couple of pictures....and words in what I think was Chinese... no schematic tho. Having a Haynes with wiring diagrams helped. (ya, Haynes....not a Bentley)
he liked the outcome when all was said and done and we got all the escaped smoke back into the wires
maybe he'll see this post...
Old Apr 20, 2008 | 01:55 PM
  #31
MLPearson79
Yeah if they're not plug and play I won't be able to do it myself. I've got a friend that could, but not me alone. I'd set the place on fire.
Old Apr 20, 2008 | 05:14 PM
  #32
Fatherdeth's Avatar
Fatherdeth
I'll try and get some pictures from the install. The lights themselves are very well constructed. Putting the lights into the holes in the bonnet is easy. The problem is there are some gaps here and there, but not too bad. My rings are painted black, so it's not too noticeable. Now, we get into the wiring part. The headlight bulbs themselves plug into the stock connector. No problem. The halo wiring and "extra" lights are a different story. There are no clips to hang any wiring on like the OEM headlight housings have. You have to be creative in keeping the wiring tucked up and out of the way. I ran the positive wiring for the halos down to the front parking lights and tapped into that wiring. The ground wiring for the left side halo, I ran down and tapped off the earth ground strap that is connected to the bonnet and chassis. On the right side, I just tapped off another ground I had for some other lighting I ran a while ago. I's kind of a pain to install these lights, but worth it IMO. The pain part comes from the running the wiring. Sorry for hijacking this thread and taking it off the original topic. Look for some more info in the next couple of days for a write up on my experience with the ebay halo headlights. I just originally wanted people to see if they could change their angel eyes from MOSS as an option.
Old Apr 25, 2008 | 01:47 AM
  #33
07BPB's Avatar
07BPB
I have them and love them.
Took around 30 minutes to install and most of that time was trying to find the right size tool.
Only problem is the fact that the headlights and fogs don't match the rings.
Old Apr 25, 2008 | 10:30 AM
  #34
MLPearson79
Well your fogs should be yellow anyway (I mean, personal preference I guess, but that's typical for fog lamps. And you can get "bluer" H7s to replace the headlamps (I replaced mine a couple of months ago with two pairs of Hella XBs at $15/pair; they match my driving lights better, but I still need to do the driving lamps, was holding off until I decided if I was going to do these or not).
Love your wheels, BTW!
Old Apr 25, 2008 | 07:00 PM
  #35
Fatherdeth's Avatar
Fatherdeth
Dude, I don't like a lot of chrome, but your car is wicked sick looking.
Old Apr 25, 2008 | 09:35 PM
  #36
07BPB's Avatar
07BPB
Haha. Cheers. My car pulls off the chrome look very nicely. The bottom picture is a bit blurry though.
Old Apr 26, 2008 | 02:12 AM
  #37
godalex's Avatar
godalex
Originally Posted by Jason C
Well I just went out and took a pic with my stupid iPhone, but it will have to wait until I get home later. You can not just take pictures off, you have to email them to your self. And of course my email settings are all jacked up, and I can not connect to my work server.
I have to respectfully disagree with Fatherdeth on the color though. With these, or at least the ones I have, the blue is very predominant. Also, they talk about a replacement bulb, but I have not seen it. So I'm not sure if it is a bulb or the entire ring.
Iphone allows a transfer via USB to your computer (reads the picture Directory just like a removable drive). FYI. ;-)
Old Apr 26, 2008 | 02:26 AM
  #38
07BPB's Avatar
07BPB
If you are talking about the replacement bulb on the moss mini site for the indicators. It is the indicator bulb itself, not the ring. Its a silver indicator bulb that appears silver and flashes amber.
Old May 3, 2008 | 10:13 AM
  #39
adbsvc's Avatar
adbsvc
I bought the set from Moss, very easy to install, but they are not very bright. They look great at night but look like crap unless its dark. Some of the photos you guys are puttin up make the angel eyes look fairly bright. Is there a way to put brighter led bulbs in? Also have any of you with the same kit changed the way they plug in?
Old May 3, 2008 | 07:15 PM
  #40
Jason C's Avatar
Jason C
Mine look alot brighter in photos. Not so bright in person.
What would you want them to plug in differently?
Old May 3, 2008 | 08:38 PM
  #41
adbsvc's Avatar
adbsvc
The pigtail on the led lamp mimicks that of the original bulb for the park lamp. I've thought about replacing that end with a connector that mimicks the original socket. This probably wont help the output of the led but at least it would provide a secure oe style connection.
Old May 5, 2008 | 09:05 PM
  #42
tekron's Avatar
tekron
I was not pleased with the stock LEDs so I put in some "xenon blue" standard bulbs for now. Plan on doing a full exterior makeover with LED's that don't flicker soon.
PS - I have looked at the halos in the projector headlights and the LED's that light them up. They are not plug and play LED's from what I remember. They were exposed and wired in a way that looks like a home made Radioshack job.
Old May 5, 2008 | 09:55 PM
  #43
Jason C's Avatar
Jason C
Thanks. See post #14.
They also list a replacement led bulb. That's what I was talking about.
http://www.mossmini.com/Shop/ViewPro...eIndexID=52440
Second item down.
Tekron,
Looking good.
Old May 6, 2008 | 05:00 PM
  #44
Fatherdeth's Avatar
Fatherdeth
I don't know which projector headlights you saw, but mine are not exposed. They fit into the hole with a rubber grommet and actually look quite nice lit up at night.
Old May 17, 2008 | 09:21 PM
  #45
89AKurt's Avatar
89AKurt
I was checking out these lights. Looks really simple, just plastic tubes bent in a circle.
Old May 18, 2008 | 12:47 AM
  #46
jerjer's Avatar
jerjer
with the exception of having slots on the back of the "plastic tube" or else the light will just shine straight thru the tube from 1 end to the other (in another word, it won't light up thru the front view of the headlights)
Old May 18, 2008 | 02:56 AM
  #47
07BPB's Avatar
07BPB
I really like your headlights. What type are they?
Old May 18, 2008 | 04:21 AM
  #48
BlimeyCabrio's Avatar
BlimeyCabrio
Hmmm... those look like electroluminescents to me...
Old May 18, 2008 | 04:25 AM
  #49
ngweibing's Avatar
ngweibing
i liek the halo lights.
Old Jun 4, 2008 | 06:54 AM
  #50
22CooperS's Avatar
22CooperS
Has anyone had any problems with quality of these lights?? Anyone had one break on them/go out?
