Interior/Exterior Air Horn - an exercise in taking a mod to the extreme!
Old Jan 21, 2009 | 05:28 AM
  #101
cartar452's Avatar
cartar452
Hornblasters has some great stuff. Try to fit this next to your exhaust
Old Jan 21, 2009 | 07:52 AM
  #102
agranger's Avatar
agranger
Yep. Cool stuff, but they aren't concerned about size or shape... made more for a big truck with lots of under hood / under chassis room. Adding a mod of this size to the MINI presents it's own unique challenges! :D
Old Jan 21, 2009 | 07:56 AM
  #103
agranger's Avatar
agranger
I've never really thought about weight. The horns aren't that heavy and the CO2 tank is a 9oz model... add a bit of other hardware and stuff and I'd say it is all still under 10lbs.
I'd be better off with a 'Nutrisystem' mod (trimming lbs from my fat ****) rather than worring about weight reduction mods, so it has never really been an issue for me. Anyway, adding a bit of weight to the low, far back end of the MCS is probably a good thing. Helps make the balance of the car more centered.
Old Jan 21, 2009 | 08:11 AM
  #104
Rally@StanceDesign's Avatar
Rally@StanceDesign
Originally Posted by TonyB
With room under the rear of the car on both the left and right side of the muffler, I've always figured that I had sufficient space for a tank and compressor. agranger, are you going to use air? If so, please do share...
What would you say is the total weight of the CO2 horn system, and about how much heavier would the tank/compressor option be?
It's not as helpful since it's a clubman (and you removed your battery box), but I have my setup down in the spare tire well. The compressor is the only real heavy part, but I'm running a pretty large one. The tank is an aluminum (no rust) 3 gallon and it's light. All in all, mine is pretty heavy but I didn't put any effort into cutting any weight. If you made your purchases with weight in mind you could keep it pretty light. There are some small compressors out there which will save you a lot of weight compared to the larger ones. You'll just have longer fill times.
Pics of my setup. I have 2 manifolds each with 4 valves. Ignore those as you'd only need 1 valve for a horn.
Prior to fitting the water trap and compressor leader hose.
Old Jan 21, 2009 | 12:03 PM
  #105
TonyB's Avatar
TonyB
Nice job RSD. Thanks for the information. One of the sets-up on Hornblaster would weigh just shy of 20 lbs. And as someone said earlier, adding weight in the back is a good thing on the MINI. I'd also add that weight down low is better as well...
I have no rear seats and lost tons of weight with the straight exhaust and smaller battery... so I don't mind adding some weight back there.
Old Jan 21, 2009 | 03:11 PM
  #106
agranger's Avatar
agranger
If you have the smaller battery going and a very trim battery mounting, you might even be able to squeeze the compressor into the battery compartment too! That would keep it clean and dry (unless your sunroof drains block up), which is always a good thing.
My CO2 setup is small enough to get the box (CO2 canister and regulator), the 4 horns and the valve setup all into the space where the driver's side muffler used to be. If I go with air, I'll have to put the compressor and tank in place of the CO2 box and run a snorkle for one of the better dust/moisture-proof compressor into the passenger cabin so I don't pull in dirty/wet air.
Stance: That's a beautiful rig in the spare-tire well. Very nice work. It needs some custom paint! :D
Old Jan 21, 2009 | 03:22 PM
  #107
TonyB's Avatar
TonyB
Battery compartment? If you mean the battery box, well, it's gone. Not the best pictures, and from long time ago, but this can give you a pretty good idea as to what I have:
The exhaust shielding is gone, leaving even more space.... Where did you source your horns? Thanks.
Old Feb 12, 2009 | 10:19 PM
  #108
Some Guy's Avatar
Some Guy
So I was doing some research because the thought of doing this kept crossing my mind, however I didnt like the idea of spending $80 on a regulator. So after a little digging I have found that most pressurized gas cylinders used a standardized thread called CGA 320. As a consequence you can easily adapt an inexpensive $40 welding style regulator to a paintball tank.
As an example:
http://www.chicompany.net/index.php?...roducts_id=172
Old Feb 12, 2009 | 10:48 PM
  #109
TonyB's Avatar
TonyB
SG, nice find. Would seem to work alright. If you give it a go, please report back. I'm very interested in doing something like this. Good luck with the Hall this Sat!
Old Apr 15, 2009 | 06:14 AM
  #110
raleel's Avatar
raleel
The videos at the beginning made me giggle like a school girl. I think I found my next mod after I get my iphone rigged up right.
Old Apr 15, 2009 | 07:16 AM
  #111
agranger's Avatar
agranger
Glad you liked 'em!
Update: I'm still only getting about 2 weeks per tank... I've got a slow leak in there somewhere.
One of these years I may put in a small compressor and tank and bail on the CO2. I still think that this is the right solution, but I think that the leak is in the regulator somewhere and I can't fix it. I don't think that paintball equipment is made for long-term use like this... maybe the adaptor above would be a solution.
Old Apr 15, 2009 | 07:48 AM
  #112
MichaelSF's Avatar
MichaelSF
I was thinking of putting something like this on mine. It's a tad more aggressive. I'm tired of not getting any respect.
Love your setup, can you put that on mine? I am not good at this kind of stuff.
UPDATE: Never mind, I found a great one for my MINI:
http://www.youtube.com/watch?v=zgQGe...eature=related
Old Apr 15, 2009 | 07:50 AM
  #113
BlimeyCabrio's Avatar
BlimeyCabrio
Aaron - I'm getting MONTHS out of a single tank on my rig, with light occasional use during the off-season... having no issues with my regulator....hmmm....
Old Apr 16, 2009 | 10:19 AM
  #114
AZblackOUT's Avatar
AZblackOUT
200 PSI of pure fury... shaking the ground beneath you... AND, its by a MINI cooper...
Old Apr 16, 2009 | 10:31 AM
  #115
Longboard Mini's Avatar
Longboard Mini
Let here that beast! Looks crazy .
Longboard
Old Apr 16, 2009 | 10:53 AM
  #116
Rally@StanceDesign
Longboard
There's nothing to hear....that's for suspension which is nice and quiet
Old Apr 16, 2009 | 11:01 AM
  #117
BlimeyCabrio
NUTS
I think I love you.
Old Apr 16, 2009 | 11:11 AM
  #118
AZblackOUT's Avatar
AZblackOUT
Originally Posted by BlimeyCabrio
NUTS
I think I love you.
That'll be our little secret
I hit the horn today on the way to work, truck cut me off in traffic... everyone stops to look around and a few people were pointing their fingers at the truck that cut me off... gotta figure it came from a lifted truck or semi, or even an SUV before you conclude on a MINI
Old Apr 16, 2009 | 11:12 AM
  #119
bluemeanie357's Avatar
bluemeanie357
You sir are a madman... that's a great mod.
Old Apr 16, 2009 | 11:20 AM
  #120
AZblackOUT's Avatar
AZblackOUT
Had a lot of people annoyed/baffled/excited at AMVIV this year... hell, it was at the palace STATION! ohhh and the strip run... I had that compressor on the whole time
Old Apr 28, 2009 | 01:51 PM
  #121
BlimeyCabrio
Ok... so my remote control only had a range of 20-30 feet... because it had a short little 12" antenna wire, most of which was in the battery box. So I extended that sucker by about 6 feet and ran it up the side and across the bottom of my rear shelf... now I get at least 50 yards of range - might get more, but I haven't tested any more than that...
Old Apr 28, 2009 | 02:02 PM
  #122
AZblackOUT's Avatar
AZblackOUT
Im guessing mine is the best because everyone waves A finger in the air when I honk...
Old Apr 29, 2009 | 11:42 AM
  #123
agranger's Avatar
agranger
I fired off my horn at Fontana today and the valve didn't close all the way! I drove another 10 sec before it finally shut up!
Old Apr 29, 2009 | 12:22 PM
  #124
checkercoop's Avatar
checkercoop
Ohhhh make sure you shoot it off tomorrow! I will be there tomorrow morning and I definitely wana hear that thing in person
Old Apr 29, 2009 | 06:08 PM
  #125
BlimeyCabrio
Mine doesn't seem quite as stupidly loud as it was when new... may not be blowing on all four diaphragms.. or maybe I just don't have the pressure as high... but it's still loud enough to be fun.
