Interior/Exterior Nothing is safe from me...
Old Mar 19, 2008 | 10:55 PM
yellowbritishrocket's Avatar
yellowbritishrocket
Well i was talking to chris(Bang110) and we decided to paint the dash pieces: after dismantling the dash(painless really) and a trip to home depot the dash is being repainted satin(flat) black!
Here is some of the pics at the primer stage...i think by the time it was all said and done about 6 coats of primer were applied...basically i used the can till it ran out lol!
chris used some bondo to fill in the airbag indention on the airbag cover...nice and smooth!
Old Mar 20, 2008 | 12:08 AM
UKSUV's Avatar
UKSUV
AND DEN?!??!?!?!?!?
Old Mar 20, 2008 | 02:15 AM
yellowbritishrocket
more than likely the other trim pieces will fall victim to sandpaper and spray paint
Old Mar 20, 2008 | 04:34 AM
PGT's Avatar
PGT
3pc dash with airbag? I thought only the 5pc had that
Old Mar 20, 2008 | 06:03 AM
afinley's Avatar
afinley
you can see all 5 pieces in the pics
I did the same thing, with great effect, only i couldn't easily figure out how to get my airbag cover off, so ive got black, black, black, crappy gray plastic, black. it looks "great"
what paint are you using? When i was younger and more foolish I had a honda which i painted the interior accents of with regular ole Krylon. It faded in about 6 months.
Old Mar 20, 2008 | 06:51 AM
PGT's Avatar
PGT
there you go....pointing out the obvious. now that my coffee has kicked in, I see it
Old Mar 20, 2008 | 06:55 AM
skillet's Avatar
skillet
I'm interested in seeing how this turns out. I'm sooo close to taking mine to a professional body shop and having it painted.... I remember the days of pulling off plastic pieces and rattle canning them...
Old Mar 20, 2008 | 12:36 PM
chaseabryant's Avatar
chaseabryant
I just painted mine a flat black too. I love it. If you don't have a paint chosen yet, I would suggest the Wurth Bumper paint. It has a nice fine spray to it so that you don't wind up with clumping like one might see from larger spray heads (Krylon gave me a problem with clumping)
Did you fill in your "airbag" imprint on the airbag cover?
-Chase
Old Mar 20, 2008 | 12:45 PM
Eric_Rowland's Avatar
Eric_Rowland
Airbag cover removal is explained here.
You need to remove three screws from the bottom of the airbag cover (don't confuse them with the two or three screws for the glovebox, which are in close proximity) Then remove the top of the dash (two torx on either side, underneath plastic panels which just pull off.) From there there are three more torx on the top, as well as two nylon retention straps that require a 10mm socket - the one on the right is tougher to get to - use an extension.
After ALL the screws are out, lift up on the bottom (if you get any resistance, check for more screws) and the cover will pivot out. Note that in the top are three green plastic screw retention pieces. These just LOVE to fall out and subsequently fall in behind the glovebox as you wriggle the cover out. Be warned!
Note that it is a breakaway cover, so don't force anything, or you can find it breaking away unexpectedly. Only handle the frame where the screws go through.
Old Mar 20, 2008 | 12:50 PM
MidniteCoop's Avatar
MidniteCoop
Lookin' good cant wait to see it completed...
Old Mar 20, 2008 | 12:51 PM
yellowbritishrocket
-Chase
yes...basically i sanded the imprint and then chris filled it with bondo...smoothed it out and started painting...one thing...if after a couple of coats of primer the bondo still shows...hit it with 220 grit to blend it then spray again...worked like a charm
Old Mar 20, 2008 | 12:54 PM
yellowbritishrocket
i let the primer set all night...after i get back from changing my oil the paint goes on
Old Mar 20, 2008 | 12:57 PM
chaseabryant
Are you going to be doing your door cards as well? I have yet to take mine off because it has been a little too cold where I am, but I cannot wait to get them done!
-Chase
Old Mar 20, 2008 | 01:08 PM
yellowbritishrocket
actually the door handle and speaker panels up front are next
Old Mar 20, 2008 | 02:23 PM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
Nice job I can appreciate the 6 coats
Old Mar 20, 2008 | 07:41 PM
yellowbritishrocket
well wetsanding is done...time for the paint...ill prolly use the whole can of paint too
Old Mar 20, 2008 | 07:48 PM
Ryephile's Avatar
Ryephile
oooOOOOooo!
Make sure to post some hot pics when you're all finished with it! Good luck!
Old Mar 20, 2008 | 09:27 PM
yellowbritishrocket
ok here is at 2 coats
airbag cover still drying a bit
Old Mar 20, 2008 | 09:30 PM
Bang110's Avatar
Bang110
Damm I did a good job of filling that airbag indent.. =) haha
Looks good! Let me know when you want to do the other parts and I will help out.
Old Mar 20, 2008 | 09:58 PM
yellowbritishrocket
im thinking flat yellow on the vent/speedo/tach/boost surrounds and flat black speaker grilles with flat yellow trim around the grilles
and yea you did an awesome job on the indent...i took your advice on the sanding when i got em home last night and it did the trick!
Old Mar 20, 2008 | 10:07 PM
that7guy's Avatar
that7guy
This look familiar somehow...Like ive seen it somewhere before....
Old Mar 20, 2008 | 10:30 PM
jimzbobs's Avatar
jimzbobs
looks good..gonna do some painting and i can use this as a guide...
Old Mar 20, 2008 | 10:35 PM
yellowbritishrocket
lol yea
Old Mar 20, 2008 | 10:36 PM
yellowbritishrocket
if you decide to bondo the airbag indent smooth you may have to bondo it twice because some bubbles may pop up
Old Mar 20, 2008 | 11:22 PM
yellowbritishrocket
and as the finishing touch...i finished a COOPER S emblem set using some semi gloss paint and the carbon fiber vinyl decals from vinyl styles
