Interior/Exterior the most important gauges
Old Mar 1, 2012 | 11:26 PM
  #51
genik's Avatar
genik
Originally Posted by Yoda Mini
Is anyone running 4 gauges? 2 gauges look good but I was thinking 4 gauges might look a little crowded. Anyone have pics?
to be honest i was looking out for four also, but im not sure what those 4 gauges should be!
here are 4gauges setup by Tron Chief from another mini forum
Old Mar 2, 2012 | 11:35 AM
  #52
Yoda Mini's Avatar
Yoda Mini
Originally Posted by genik
to be honest i was looking out for four also, but im not sure that those 4 gauges should be!
That does look a little crowded. A possible solution would be to use SPA gauges but they definitely don't have an OEM look.
Old Mar 2, 2012 | 12:11 PM
  #53
genik's Avatar
genik
yeah maybe 4 are a little crowded but as for the SPA gauges i don't like them at all because they don't have the OEM look, something which i believe is a must for a mini
Old Mar 2, 2012 | 01:06 PM
  #54
DneprDave's Avatar
DneprDave
I've got the Marshal gages. Boost/Vacuum, Water temperature, Oil temperature and Oil pressure.
I made my own gage mount and gage pods out of 1/8" Aluminum and 2" ABS drain pipe.
I used a Cravenspeed adapter for the oil temp and the oil pressure. I mounted the oil pressure sender remotely using a piece of 1/4" hydraulic hose, that left enough room to also mount the oil temperature sender onto the Cravenspeed adapter.
You can use the Boost/Vacuum gage to maximize your gas mileage, just keep the needle in the vacuum range as much as you can. Old Pontiacs had a vacuum gage, they called it an Econ-O-Meter.
Dave
Old Mar 2, 2012 | 01:21 PM
  #55
genik's Avatar
genik
very very impressive,but i don't understand what do you mean by that you made by yourself the gage mount and gage pods?
Old Mar 2, 2012 | 04:02 PM
  #56
DneprDave's Avatar
DneprDave
I cut some lengths of black ABS pipe for the gage pods, making sure that the mounting screws on the back of the gages would stick out 1/4" past the pipe sections.
I made a cardboard pattern the shape of the mount I was making. It took me four tries to get a shape that allowed me to see all four gages through the steering wheel. I transferred the pattern shape onto some 1/8" aluminum sheet.
Then I cut out the shape with a scroll saw.
I had to curve the aluminum a bit so it would clear the dashboard.
I smoothed the edges with a file and a sander then primed it with aluminum primer, I painted it satin black.
Here it is with the gages screwed to it.
I matched the pitch of the tachometer's assembly screws with some longer screws at the hardware store and screwed my bracket to the back of the tachometer. There are three screws on the back of the tachometer, I only used the top one. it is very solid and doesn't vibrate even a little.
Dave
Old Mar 2, 2012 | 11:22 PM
  #57
oldcracker's Avatar
oldcracker
Dave
wow nice work!
do you mind explaining how you mounted the oil pressure and temp sender with the hydraulic hose again?
Old Mar 3, 2012 | 10:00 AM
  #58
DneprDave's Avatar
DneprDave
The Cravenspeed adapter is hex shaped and there is a hole tapped for 1/8" pipe on each flat, so when it is screwed into the head a hole will be accessible to screw the oil pressure sender into. The oil pressure sender is pretty large and when screwed into the adapter, leaves no room for any other kinds of senders, like an oil temperature sender.
With the oil pressure sender mounted remotely, there is room to screw the oil temperature probe to the Cravenspeed adapter.
I had a 2 foot long hose made at a hydraulic supply store with 1/8" male pipe threads on one end and 1/8" female pipe threads on the other end. I used a couple of brass 1/8" street ells to get the pressure tap pointing in the right direction. Then I screwed the hose into the street ell, routed the hose around the coolant expansion tank and under the radiator support on the driver's side.
I used nylon tie wraps to secure the hose and the pressure sender to the support, it is not visible when everything is in place.
The oil pressure sender needs an electrical ground that is normally supplied through the metal threads when it is screwed to the engine, but because it is now on the end of a hose, I grounded the metal housing of the sender by hose clamping a ground wire to it.
Dave
Old Jun 17, 2012 | 11:55 PM
  #59
genik's Avatar
genik
There where some issues when one would chip a mini for more bhp, the engine temp would rise close to 100oC (alas on the JCW it only goes up to 85oC if im not mistaking) so that overheating would hurt the engine. What gauge should i have fot the engine temp? A water temp gauge?
Old Jun 18, 2012 | 07:29 AM
  #60
tominizer's Avatar
tominizer
DneprDave, what do you estimate it cost you to put that cluster together, all said and done?? BTW, nice work.
Old Jun 18, 2012 | 07:38 AM
  #61
BlueToy's Avatar
BlueToy
Great idea...great fab skills...great execution
-Steven
Old Jun 18, 2012 | 08:36 AM
  #62
DneprDave's Avatar
DneprDave
I already had the aluminum and the 2" ABS pipe, So the gage mounting cost me nothing.
There was the price of the Marshal gages,
http://www.marshallinstruments.com/c...per_gauges.cfm
Plus the cost of the Cravenspeed adapters,
http://www.cravenspeed.com/gauge-sender-adapters/
And miscellaneous wire, paint, and flexible wire sheathes, it came close to $500.00
Dave
Old Jun 18, 2012 | 08:56 AM
  #63
DneprDave's Avatar
DneprDave
MINIs run hot by design, to keep emissions down.
My water temperature runs around 220F, 105C. There is enough extra capacity in the cooling system to handle a tune.
Dave
Old Jun 18, 2012 | 12:55 PM
  #64
genik's Avatar
genik
Dave
A Dutch friend was telling me about problems in Holland with chipped Mini Cooper S R56. The temperature in the engine would go much too high, also the oil temperature would be too high and that would damage pistons and cylinder. In Holland (and probably in general too) when you would chip a Mini Cooper S you have to do things at your car, like a bigger intercooler and an oil cooler. There were loads of engines on the Dutch Miniclub that were damaged after a chip update!
A JCW R56 have different pistons than a normal R56 Cooper S and also have engine software that when you drive a long time above 5000 rpm then the temperature of the cooling water will go back to 85 degrees and not 105 degrees that would hurt the engine!
Old Jun 18, 2012 | 02:33 PM
  #65
DneprDave's Avatar
DneprDave
All modern cars coolant runs at temperatures above 100C, it is why they have pressurized cooling systems, so that they don't boil at the higher temperatures.
If a tune (chip) is damaging pistons and cylinders, it is because they are running too lean, or the ignition timing is too far advanced, not because of an inadequate cooling system.
Dave
Old Jun 18, 2012 | 03:01 PM
  #66
czar's Avatar
czar
Both the S and JCW models with the N14 engine, have a two stage electro controlled thermostat.
Stage 1: light load throttle cruising, the coolant temperature is controlled at 105 ºC
Stage 2: prolonged heavy load throttle use, the coolant temperature is regulated (full flow open circuit) down to 85 ºC
Old Jun 19, 2012 | 02:28 PM
  #67
genik's Avatar
genik
interesting info there czar, thanx,
though i wonder why if there are two stages and the later is the optimum, why isn't there just one stage regulating the temp to 85 in all occasions, wouldn't that be best for the engine?
Old Jun 19, 2012 | 03:42 PM
  #68
czar's Avatar
czar
To you and me, this seems like the best solution, however we are not governed by emission regulations to the degree that engine designers are, with the ever stringent emission regulations, and so lighter compact smaller displacement engines utilising GDI (gasoline direct injection) are now common place, and to produce decent power/torque levels, this is done with increased compression ratio and twin scroll turbo's, this in turn increases generated heat, which is good for you, as it increases MPG and lowers emissions, the reason a second stage cooling of 85 ºC is brought in, is to help reduce the rapidly generating heat from heavy load boosted throttle conditions, once normal light throttle conditions are resumed, you want maximum MPG and so you need heat, to maximise the engines volumetric efficiency (VE)
Old Jun 19, 2012 | 09:16 PM
  #69
genik's Avatar
genik
wow, thanx for the great explanation regarding the two stage electro controlled thermostat the R56 has.
1. I wonder though, in that case is there a good reason why i should have a water temp gauge?
2. what gauges would you recommend that the 2008R56 should have and why? (dont really want a scangauge)
Old Jun 21, 2012 | 07:38 AM
  #70
czar's Avatar
czar
1. I wonder though, in that case is there a good reason why i should have a water temp gauge? No, if you add gauges, you'll spend time watching them whilst driving, and give yourself undue concern, with every fluctuation!
2. what gauges would you recommend that the 2008R56 should have and why? (dont really want a scan gauge) As above, why give yourself undue concern ? just drive your car, gauge and worry free and enjoy it.
Old Jun 21, 2012 | 10:05 AM
  #71
genik's Avatar
genik
heh u always make interesting points and you speak like a true practical racer, thanx
to be honest i mostly want them for the looks! but while having them (for the looks yes) i want them to be worth of something
Scm68
Jan 27, 2016 12:33 PM
Doc Pain
Oct 28, 2015 07:09 PM
Fourflys
43
Oct 20, 2015 09:42 AM
papawhiskey
Sep 30, 2015 02:50 PM
krohm
Sep 28, 2015 12:16 PM
