Interior/Exterior bumper help!!!
Old Feb 27, 2008 | 01:14 AM
Type R 564's Avatar
Type R 564
bumper help!!!
(snowing at big bear and icy roads)
ya well thankfully thats the only thing that broke...since that happened i cant screw in the bottom bolt so im using zip ties instead as its been working fine for now...u guys think i need to replace that broken peace right away or can i drive with it like that for a while...
and i still want to lower the front end of my car!!!! hahaha im an idiot!!!
Old Feb 27, 2008 | 07:46 AM
batrugger's Avatar
batrugger
Aero kit bumper, right? We had ours on for over 6 months with just the two top bolts and two top screws holding it on. The middle bolt and none of the plastic fasteners were used and we never had any issues.
Old Feb 28, 2008 | 02:17 AM
xnotfunkylex's Avatar
xnotfunkylex
Should be fine. I don't have the aero bumper, but my MCS bumper only has the top 4 screws holding it on and it doesn't hang any lower to the ground.
Old Feb 28, 2008 | 04:35 AM
Speedwing's Avatar
Speedwing
A small piece of aluminum flashing and some pop rivets, maybe some epoxy, and I'd have that fixed in a few minutes.
Old Feb 28, 2008 | 09:23 AM
gaffer's Avatar
gaffer
Speedwing is right. I fixed the wife's Mazda like that a few years ago, still doing fine. Fashion a piece of flashing to fit behind the crack, with some overlap on each side and top. Drill a small hole on either side of the flashing. Use the flashing as a template to drill a hole on both sides of the crack. Re-drill the holes to snuggly fit your pop-rivet. Hold the flashing behind the crack and pop in the rivets. 2 rivets should do the job, one on each side. Touch up paint, epoxy or whatever to make repair not noticable.
carid
Dec 28, 2025 04:11 AM
n0mis
MINI5280
11
Mar 9, 2016 05:04 PM
ccfirelt
Oct 18, 2015 01:02 PM
drum6g
Sep 29, 2015 01:15 PM
BMC_Kid
Sep 27, 2015 04:31 PM
