Interior/Exterior Shifter bushings
Old Feb 22, 2008 | 05:37 PM
chad1140's Avatar
chad1140
Shifter bushings
Does anyone know where I can buy shifter bushings like the ones that come with the B&M and Ebay short shift kits? I think my only option at this point is to buy an ebay one and cannabalize the kit for the bushings so I can run it with my craven. Thanks in advance
Old Feb 22, 2008 | 07:44 PM
yellowbritishrocket's Avatar
yellowbritishrocket
ive always wondered if bushings can be had....maybe minimania has some oem ones?
Old Feb 22, 2008 | 08:38 PM
yellowbritishrocket
promini makes a shifter with the aluminum pivot joints....is there anyway we can convince them to sell the bushing kit?
Old Feb 23, 2008 | 06:12 AM
CmdrVimes's Avatar
CmdrVimes
Stuck in Reverse
There was a previous conversation about this and Craven Speed actually stepped in at one point and mentioned that if there was enough interest they could be swayed to make a run of them. So it might be worth your time to contact them and see what they say.
Old Feb 24, 2008 | 02:49 PM
chad1140's Avatar
chad1140
Well I talked to Craven and there would need to be a bit more interest and a bit more time so I went and dropped the dough on a cheapo ebay shifter that I will run the bushings from.
Old Feb 24, 2008 | 09:05 PM
Some Guy's Avatar
Some Guy
If I may ask, what benefit does one get from swapping out the bushings in the shifter?
Old Feb 25, 2008 | 07:15 AM
CmdrVimes's Avatar
CmdrVimes
Stuck in Reverse
It gets rid of a lot of the mushiness of the shifter. The stock setup has a rubber gasket running around the shift housing where it mounts up to the body of the car. With that gasket the housing has a tendency to move around slightly while shifting and manifests itself as a sort of spongy feel.
The solid bushing replace the rubber at the four corners of the housing and create a pretty solid mounting surface that doesn't tend to shift around nearly as much. They create a much more solid shift feeling.
Of course it's all a matter of preference and feel. Not everyone is going to notice the same thing. However, of all the people who have driven my car they all seem to like the feel of my B&M.
Old Aug 18, 2008 | 07:25 PM
suspencer's Avatar
suspencer
Since the '04-'05 kit was discontinued, could the bushings from the '02-'04 kit be put on my '05, or would they not fit?
Old Aug 19, 2008 | 12:09 PM
CmdrVimes's Avatar
CmdrVimes
Stuck in Reverse
My initial thought on the older bushings fitting the newer model would be that they would not work. The shifter housing was changed which is why there is a newer model of the short shifter.
Old Aug 21, 2008 | 08:23 AM
suspencer's Avatar
suspencer
yeah... that's what I figured. It looks like I'm stuck with my plastic bushings unless I can scrounge up a discontinued '05 B&M ssk. Or if we could get a list of enough people willing to purchase just the bushings, I'm sure that some distributer would want to take advantage of the demand for them.
YaTuSabe
Aug 23, 2018 11:41 AM
02miniSguy
Nov 17, 2015 10:29 PM
pahg
Oct 5, 2015 11:50 AM
vetsvette
Oct 1, 2015 12:59 PM
MINI Stupor
Oct 1, 2015 11:36 AM
