Interior/Exterior Help! Front Bumper Parking Light Burned Out!
Old Feb 8, 2008 | 04:25 PM
Thrilhouse's Avatar
Thrilhouse
So I'm following an SUV the other night, and I was observing the reflection of my headlights/parking lights on the SUV's tailgate. Well, it seems the drivers' side parking light is burned out. The left turn signal works just fine, just the parking light is out.
How does one replace this light? Does the entire bumper cover need to come off? If I have a dealer replace the bulb, is it going to cost me an arm and a leg? Any input would be appreciated! Thanks in advance!
The culprit, circled in yellow...
Old Feb 8, 2008 | 04:41 PM
AutoXCooper.com's Avatar
AutoXCooper.com
yep, pull the bumper skin off, after you make sure and get the right blub from the Dealer.
Old Feb 8, 2008 | 04:49 PM
aminicooper's Avatar
aminicooper
Open bonnet, look behind that light, remove wire, turn receptacle to remove. replace with a $3 bulb (wedge 194)
Old Feb 8, 2008 | 05:38 PM
AutoXCooper.com
On my 05 R50 you can change the turn signal as stated above, but that driving light had to be replaced with the bumper skin off. Not a great MINI design.
Old Feb 8, 2008 | 07:41 PM
hemiheaded18's Avatar
hemiheaded18
My 03 all that you have to do is find the proper socket, twist it and it pulls out. Not hard at all. And the OEM bulb number is 2825 but a 194 will work in its place no problems.
Old Feb 8, 2008 | 07:50 PM
the_red_car's Avatar
the_red_car
Just replaced the whole assembly....
It's easier on a driving/fog light to remove the wheel and undo the 4 or so plastic pop screws, one verticle screw from the c clip up - the wheel liner comes out and - voila, the light, socket and(if a rock has taken on your light assembly) the fog/drivers light unit!
There are details if one searches.
As for the parking light/signal - as noted above!
FLYM1N1
Aug 15, 2015 11:20 AM
smlzilla
Aug 14, 2015 07:00 PM
JHolland
Aug 13, 2015 10:47 PM
skippermini
Aug 12, 2015 10:05 PM
