Interior/Exterior Down Tubes/HU Removal
Old Jan 9, 2008 | 10:15 PM
MaxMini81's Avatar
MaxMini81
Wanderer
Hey all. I'm in the process of installing a new Sirius unit in my Mini. I've done a lot on my car, but this is new to me. I searched for downtube removal but it didn't really come up with anything. If any of you can give me some kind of step by step instructions or a link to them it would be very highly appreciated. The same thing goes for the Head unit, although I'd like to think I could figure that out once the tubes are out. Thanks
Old Jan 9, 2008 | 10:25 PM
QXXOTIC's Avatar
QXXOTIC
downtubes
Sorry that I don't have a link to them but I did see something recently about this. There are differences between the early and 05-06 tubes since the later ones are flared at the end and are supposed to be removed from the bottom rather than straight up as in the earlier verisons.
This is something that I have to do as well and I didn't realize the differences in the tubes till i received the newer ones for my older '04 MCS. Not sure if they are usable so I could also use some info as well.
Jim
Old Jan 9, 2008 | 10:38 PM
MaxMini81's Avatar
MaxMini81
Wanderer
Well I have a 2004 S. Good to see this got more complicated. Lets see if we can't get an answer. I'm sure quite a few people have done this. So please don't be shy and speak up!
Old Jan 10, 2008 | 04:47 AM
nedkelly's Avatar
nedkelly
The following link isn't quite a downtube tutorial, but it does show the removal process when I installed a Dension ICE>Link into herself's cabrio, hope it helps :
http://miniclub.ie/modules.php?name=...viewtopic&t=73
Old Jan 10, 2008 | 06:23 AM
CooperGear's Avatar
CooperGear
From: Greater Chicagoland. Ich Bin Ein Midwesterner!!!
You don't have to remove the tubes to get the HU out. You must un-screw them, the 2 torx on each side will loosen them up. Then pull on the bottom of the center dash and it will pop forward enough to let you move the tubes. Pull the tubes toward the back of the car out from under the center dash piece and then you can spread them enough to get at the screws holding the HU in place.
Hope that this helps.
Blake
UncDeo
Nov 4, 2019 04:08 AM
BRracing
Oct 24, 2015 10:07 PM
Sep 2, 2015 11:15 AM
Sep 2, 2015 09:05 AM
broncobuddha
Sep 1, 2015 06:32 PM
