Interior/Exterior Dead pedal removal
Old Dec 27, 2007 | 05:35 PM
ANT818's Avatar
ANT818
Dead pedal removal
Has anyone removed the dead pedal from the R56? Any hints would help.
Old Dec 27, 2007 | 05:41 PM
Dr Obnxs's Avatar
Dr Obnxs
Slide Hammer?
Did you really mean any hints? Or just usefull ones...
Matt
Old Dec 27, 2007 | 06:40 PM
jimmy_racoon's Avatar
jimmy_racoon
Dead Pedal
I took mine off to upgrade to stainless...
There was a small tab on the upper right portion that you can pry gently with a screwdriver and it pops right out.
Not sure it matters what model you have.
My guess is they are pretty much the same.
Good luck.
Old Dec 28, 2007 | 06:16 AM
FP's Avatar
FP
Do you want to sell your OEM pedal?
Old Dec 28, 2007 | 04:36 PM
jimmy_racoon
OEM Parts
Sure, I could part with it for $15, plus shipping.
I also have the OEM brake and clutch pedal covers that I just replaced, as well as an entire gas pedal mechanism...just don't know what they be worth.
Old Dec 28, 2007 | 05:38 PM
FP's Avatar
FP
Sold on the dead pedal.
I would take the others if they were for an automatic.
Old Dec 28, 2007 | 06:18 PM
FP's Avatar
FP
I guess I won't be taking the dead pedal after all. This is what I thought the pedal looked like for the MCS.
WTB: Set of MCS Pedals for Automatic-nmi7609.jpg
Old Dec 29, 2007 | 09:22 AM
JMike's Avatar
JMike
Hey, just for a novice. What is a Dead Pedal?
Old Dec 29, 2007 | 09:40 AM
Blue Cooper's Avatar
Blue Cooper
The dead pedal is where you rest your foot when you are not using the clutch.
Old Dec 29, 2007 | 06:18 PM
ANT818's Avatar
ANT818
I took the dead pedal out. Had to break the foam under the carpet. It was only an hour before I put it back. If i could get another from mini, I'd modify it. But it doesn't seem like its available without buying the entire carpet. For now I'll live with the dead pedal the way it was designed. I still feel that its too close to the clutch.
Old Jan 5, 2008 | 06:00 PM
Chili Cart's Avatar
Chili Cart
Why do you want to remove the dead pedal? Does it get in your way?
Old Jan 5, 2008 | 06:19 PM
ANT818's Avatar
ANT818
yes, my left foot is hitting it when I go to engage the clutch.
womble
Classic Mini Talk
Aug 24, 2015 12:52 PM
greekzilla
Aug 23, 2015 03:44 PM
Super Coop
Aug 17, 2015 05:09 PM
Herleman
Aug 16, 2015 06:41 PM
minipopkart
Aug 13, 2015 05:22 AM
