Interior/Exterior driving lights button
Old Dec 9, 2007 | 11:20 AM
genik's Avatar
genik
Plz show us where did the dealer positioned your driving lights button! Cause i have a feeling that it can be placed in more than one spot! Lets see where the best place for it is!
Old Dec 9, 2007 | 12:24 PM
gjhsu's Avatar
gjhsu
Mine is on the color line, just to the left of the steering wheel. Works ok there.
Old Dec 9, 2007 | 12:25 PM
Minidrivr's Avatar
Minidrivr
There is one spot for the OEM driving lights. On the left side of the steering column in the dash color line.
Old Dec 9, 2007 | 01:00 PM
genik's Avatar
genik
is it possible to see a pic?
Old Dec 9, 2007 | 01:34 PM
Nimcosi's Avatar
Nimcosi
Old Dec 9, 2007 | 02:19 PM
ghosthound's Avatar
ghosthound
im sure you can custom mount the switch anywhere you want with enough time and money but there is actually a color line piece specially made for the button.... i highly doubt a dealer would circumvent a factory piece to custom install and cut up someones dash.
Old Dec 9, 2007 | 02:22 PM
genik's Avatar
genik
Thanx for the contribution Nimcosi! Nice interior by the way!
Old Dec 9, 2007 | 03:32 PM
msh441's Avatar
msh441
Originally Posted by ghosthound
...there is actually a color line piece specially made for the button.
Exactly. I saw the part with the switch in place before it was installed.
I would guess that if you wanted to put it somewhere else, you could (provided you keep the original color-line trim piece that comes off the dash). I haven't had any complaints with the factory position, myself.
Old Dec 9, 2007 | 03:40 PM
oldopelguy's Avatar
oldopelguy
Especially since in order to order the switch itself you have to order it with one of the color line pieces. And there's a whole set for sale in the classified section (by me, for cheap) to make it even easier to do it the way MINI intended.
Old Dec 9, 2007 | 04:27 PM
sarafil's Avatar
sarafil
Originally Posted by Nimcosi
this is where it is on our MINI as well.
I believe the switch comes as part of the "color line" panel since they have different part numbers depending on what color your "color line" is.
Old Dec 9, 2007 | 08:34 PM
shokk's Avatar
shokk
7th Gear
Old Dec 10, 2007 | 01:21 PM
MiniJayhawk's Avatar
MiniJayhawk
I have color line and mine is one of the toggle switches at the bottom of the center dash. Personally, I like mine where it is.
Old Dec 10, 2007 | 02:02 PM
oldopelguy's Avatar
oldopelguy
No, your switch is for the fog lights. This thread is about the driving lights, which are the little ones mounted in front of the grill on top of the bumper.
Old Dec 10, 2007 | 02:09 PM
MiniJayhawk
Ah! Nevermind. I'll shut up now.
Old Dec 11, 2007 | 08:48 AM
Salty's Avatar
Salty
I'm with you, I consider those driving lights as well... fog lights should be yellow.
Old Dec 11, 2007 | 10:06 AM
oldopelguy's Avatar
oldopelguy
so you know
On using fog lights as driving lights:
http://mydrive.roadfly.com/blog/armychief/268/
Old Dec 11, 2007 | 11:21 AM
Nimcosi's Avatar
Nimcosi
Interesting. I typically only use them when it is foggy (dense or otherwise), and I use the rear fogs to make me more noticeable in the same conditions. I wonder if is correct to use them in with falling snow as well?
Old Dec 11, 2007 | 11:30 AM
Nimcosi's Avatar
Nimcosi
Following correct fog light usage links I came to this.
Also a couple of wikipedia entries 1 and 2
Old Dec 11, 2007 | 06:53 PM
ghosthound's Avatar
ghosthound
i use them when the weather is bad... IE rain/fog. It doesnt snow in sacramento
Old Dec 12, 2007 | 09:12 AM
Salty's Avatar
Salty
I just mean you can't really turn them off. When my lights come on, half the foglights come on too...
Old Dec 12, 2007 | 09:14 AM
Minidrivr's Avatar
Minidrivr
Yes. The R56 has split fog lights. The top half (separate bulb) acts as a running light.
Old Dec 14, 2007 | 05:33 AM
gos1's Avatar
gos1
Default location for the driving lights button...
On my mini, the dealer placed the light switch in the default location:
Old Apr 15, 2008 | 06:46 PM
genik's Avatar
genik
My mini dealer didn't place a switch for the driving lights, they light up only when i turn on the xenon high head lights using the toggle switch! Can this be due to the fact that i live in Europe?
Old Apr 16, 2008 | 08:17 AM
aem421's Avatar
aem421
Maybe this will help you out...
http://motoringfile.com/files/R56_aux_lights.PDF
Wohnson89
Jun 10, 2020 04:53 AM
ryGuyMCS
Oct 20, 2015 02:24 PM
JHolland
Aug 13, 2015 10:47 PM
