Interior/Exterior need help removing A, B, and C interior pillars!
Old Dec 17, 2007 | 06:44 PM
  #26
UKCoopeR's Avatar
UKCoopeR
oops double post :-(
Old Dec 17, 2007 | 06:50 PM
  #27
shooler's Avatar
shooler
Originally Posted by pimpedout97x
so if i pull starting at the windshield, itll come out, and will any clips break? at that point(if i dont cut the strap) could i put it back in and itll clip back in?
IF i cut the strap, can it be re installed, it just will mess up the airbag? can i just disconnect the airbags in the A and C pillars? i really could care less about them, lol.
ive heard there's a way to get the pillars off without cutting the strap/breaking anything, and reinstalling them.
If you remove them the way you are supposed to, you will break the plastic clips. Cutting the straps and reinstalling the covers won't hurt the airbags, but it will probably hurt you when the cover comes flying at you and your passenger if the airbag deploys.
Old Dec 17, 2007 | 07:32 PM
  #28
pimpedout97x's Avatar
pimpedout97x
How would I disconnect the airbags so they won't deploy ever? (just the pillar ones)
Old Dec 17, 2007 | 07:37 PM
  #29
pimpedout97x
Originally Posted by UKCoopeR
i didn't remove the A or B pillars
but i removed my C pillars in order to take out the rear seat belts then re-installed the pillars
i just used a soft tipped pry bar very gently, borrowed a buddy to help, and took my time. i actually did it over the course of 3 days lol
if you aren't in a rush and just work the clips you can get them off without breaking them, just have to look at them and make sure you aren't pushing the clips in the wrong direction etc
hope that helps a bit
i remember it was quite frustrating
Ya see I got the back ones off as far as the clips go, but its that strap. Is there way to get the strap off without cutting it? Or do you HAVE to cut it?
Old Dec 17, 2007 | 09:43 PM
  #30
UKCoopeR's Avatar
UKCoopeR
i could actually fit the wrench in where it needed to go with the strap still connected, just held the plastic out of the way. are you taking your's off for painting or something?
Old Dec 17, 2007 | 10:53 PM
  #31
UKSUV's Avatar
UKSUV
Ive already told you how to take them off.. . Okay, one more time...the red marking is the path of the airbag. It's one piece. The connector is a small green piece. Theres no reason you should want to disconnect them unless you have a full cage. But whatever. There is a Torx bolt that holds on the front of the airbag. As far as the black straps go...you have to work at the clip with a few small common screwdrivers. Everyone is right..the pillar covers are one time use...but CAN be pulled off intact if you take your time. I dont know how much more we can say. If you decide to cut the straps its your call. Here is a dirty a## pic of the interior of my car when we were gutting it...
Old Dec 18, 2007 | 04:14 AM
  #32
pimpedout97x
suedeing the headliner, A, B, and C pillars black
thanks, sorry about that lol!
also, i didnt know the airbag was one piece. i thought that it was separate airbags in the A and C pillars
Old Dec 18, 2007 | 05:55 PM
  #33
pimpedout97x
finally!!!!!!!!!!!!!!!!!
lol
the A pillars i got out, all clips and straps are fine.
the C pillars....well....i hate to say it, but....i killed them...sorta
i COULD NOT get the straps off. i cut them in frustration.
the pillar isnt gonna fly and hit anything in the event the airbags deploy, except hit the back of my box.
who cares?
when the day comes that the box comes out, ill buy 2 new C pillars, no biggie.
Old Dec 18, 2007 | 05:58 PM
  #34
UKCoopeR's Avatar
UKCoopeR
post pics
Old Dec 18, 2007 | 06:01 PM
  #35
pimpedout97x
the parts are getting dropped off tomorow FINALLY since i have everything out now!
heres pics of the suede though:
https://www.northamericanmotoring.co...d.php?t=121424
Old Dec 18, 2007 | 06:19 PM
  #36
UKSUV's Avatar
UKSUV
FINALLY!!!!
Old Dec 18, 2007 | 06:40 PM
  #37
shooler's Avatar
shooler
That's the same thing I am doing, but charcoal instead of black. I'm curious to see how yours turns out.
Old Dec 18, 2007 | 07:15 PM
  #38
pimpedout97x
Im now sorta debating doing black vinyl on the pillars. What do you think? Im more on the suede side, but vinyl is still an option.
The top dash will be vinyl though, thats why im thinking suede
Kimolaoha
Jul 5, 2023 01:04 PM
greekzilla
Aug 23, 2015 03:44 PM
Phantogram
Aug 12, 2015 12:11 PM
quality_sound
Aug 7, 2015 09:36 AM
