Interior/Exterior Konigseder kit
Old Aug 26, 2007 | 09:06 PM
catchMCS's Avatar
catchMCS
Konigseder kit
so after going to a car show here in pittsburgh yesterday i decided that i need to step it up a lil bit.. i have seen pic of the konigseder wide body kit but i just cant find out where to buy it at. does anyone know where i can buy it???it would be a big help i am tryin to get it soon be4 the next show
Old Aug 26, 2007 | 09:56 PM
xnotfunkylex's Avatar
xnotfunkylex
I think that this is the kit that you are talking about right? estrictlyforeign.com sells it. Here is the link
http://www.estrictlyforeign.com/asp/...egory=1&ID=885
Old Aug 27, 2007 | 05:57 AM
Rally@StanceDesign's Avatar
Rally@StanceDesign
Hahah when is the next show? Planning to get an extreme bodykit like that painted and fitted and then ordering the proper wheels to fit will be quite the challenge.
Any ideas for wider low offset wheels yet? My friend is debating the same kit but has been unable to determine what width and offset to go with. No sense in having a widebodykit and 17x7 et 40 wheels
Old Aug 27, 2007 | 06:03 AM
StoopidGirl's Avatar
StoopidGirl
http://www.koenigseder.at
Old Aug 27, 2007 | 06:04 AM
Tüls's Avatar
Tüls
Turbius Maximus
Old Aug 27, 2007 | 08:18 AM
ScottinBend's Avatar
ScottinBend
From the SF site.........
[FONT=Arial]**JR NEW WIDE MINI KIT
[SIZE=-1]This new Mini Kit is the epitome of Wide. Brought to you Exclusively by SF, this kit comes complete with front bumper, rear bumper, wide sides, fender flares front 1.2" and rear 1.5" . This kit can handle wider tires too, front and rear 18x8 225/40/18. Comes in high quality hand laid fiberglass, offered from SF. WoW![/SIZE] [/FONT]
Old Aug 27, 2007 | 08:24 AM
El_Griton's Avatar
El_Griton
I would hope you could run wider tires then that! hell Im running 225/35/18's with the stock body, and suspension. I am doing some springs so inner fenders will need to be cut but thats it. the way those things stick out you should be able to run way more offset and WAY bigger tires.
Old Aug 27, 2007 | 08:48 AM
Tüls's Avatar
Tüls
Turbius Maximus
the "super wide" kit be koningseder fits 18 x 11" wheels I belive... there are two one is not so wide.... you can easily fit 255s on a 10" wheel
Old Aug 27, 2007 | 08:52 AM
mcs22004's Avatar
mcs22004
So much for scrub radius.
Old Aug 27, 2007 | 09:06 AM
Tüls's Avatar
Tüls
Turbius Maximus
well being that the wheel is getting wider but not changing offset (unless running a spacer with narrow wheels) I dont thing Scrub Radius is an issue... you are only changing it but not ruining it...
Old Aug 27, 2007 | 09:58 AM
Rally@StanceDesign
Who cares anyways....it would still work perfectly fine even if the scrub radius was altered a little.
molala
Oct 2, 2015 01:53 PM
Gremothra
Sep 9, 2015 08:42 PM
OutMotoring
Sep 8, 2015 06:27 AM
M7Speed
R58 :: Coupé Talk (2012+)
Sep 3, 2015 07:29 AM
Sean Pine
Massachusetts Motoring Club
Sep 2, 2015 08:16 PM
