Interior/Exterior having install problem with boost gauge
Old Jul 2, 2007 | 08:21 AM
ggoldberg1340's Avatar
ggoldberg1340
I bought a stewart warner boost gauge and was able to install it up to the point of finding were to attach the hose at the turbo charger. I followed all the instruction till this very last and critical point .....any help on this last part ? I have a 2006 s cabrio .
Old Jul 2, 2007 | 10:39 AM
chuckt's Avatar
chuckt
If you have an '06 MCSc then you can use the FPR connection on the passenger (LHD) side on the inkake.
You will need a short piece of vac hose, ~1" to 1.5" long and a tee connecton, I don't know if your gauges came with a compatible fitting or not. I got mine at AZ because the AM supplied fitting wasn't quite right. You should be able to get at this connection without taking the IC off as you would need to do if you use the FPR end of this line.
Old Jul 2, 2007 | 12:58 PM
ggoldberg1340
That works and thanks
Thank you for your help , It was easy till i got to that point ...then i need not want to make a mistake .
ggoldberg1340
Old Jul 3, 2007 | 02:31 PM
ggoldberg1340
Dumb question ......do you cut that tube and insert tee ?
I have the tee and the extrs tubing , but i did not want to cut untill i was sure .
thnks
Old Jul 3, 2007 | 05:02 PM
chuckt's Avatar
chuckt
No, don't cut it. I put mine on like this:
BOOST
|---------- FPR
INTAKE
with the short piece of Vac line between the tee and the intake.
silence2-38554
98
Sep 21, 2016 02:52 PM
wkp1219
Nov 13, 2015 07:52 AM
squawSkiBum
Oct 2, 2015 09:21 AM
