Interior/Exterior Stock tail lights - can I re-paint the chrome trim?
Old May 9, 2007 | 10:17 PM
n1ftyneil's Avatar
n1ftyneil
Hi All.
My car is going through some MAJOR re-painting and becoming very red and white...
A glaring bit of chrome on an otherwise smooth red boot is the chrome surround to the tail lights. Anybody opened these up before? I know the fronts have been attempted.
I dont just want to buy aftermarket clears, becasue the stock red tails look great with my paint. Would really appreciate some input before I screw something up!
Cheers!
Neil
Old May 9, 2007 | 10:29 PM
El_Griton's Avatar
El_Griton
I know if you smoke them the crome is really hard to see. but that might defeat your red and white color scheme.
Old May 9, 2007 | 10:44 PM
xnotfunkylex's Avatar
xnotfunkylex
I know at least one person has done it here. They tinted the inside of the light instead of the outside. I think their name is rallymini. And I think they used a dremel to cut it open, but I am not 100% sre on that.
Old May 9, 2007 | 11:05 PM
n1ftyneil's Avatar
n1ftyneil
EEk haha dremmel is scary and I'm a pretty creative guy! Thanks for the tint idea, we took a look at it buyt the dark really looks weird with all the red. The actual red lights look perfect.
Old May 9, 2007 | 11:11 PM
terryg's Avatar
terryg
I'm looking to do the exact same mod. Let me know if you come up with something.
Old May 10, 2007 | 06:56 PM
n1ftyneil's Avatar
n1ftyneil
Blah maybe I'll just have a go and accept that I might wreck them!
Old May 10, 2007 | 08:11 PM
UKSUV's Avatar
UKSUV
I will be painting ALL the chrome on my car as soon as I get back. As for the head/tail lights...you either have to bake em or dremmel them.
Old May 10, 2007 | 08:46 PM
sagworks's Avatar
sagworks
running with scissors
I spoke with someone at the dragon who dremeled theirs open. He gave me the how to. It really does not sound too bad.
Old May 10, 2007 | 09:39 PM
batrugger's Avatar
batrugger
http://www.motoringunderground.com/f...?t=3430&page=3
Old May 10, 2007 | 09:50 PM
Rally@StanceDesign's Avatar
Rally@StanceDesign
I was the first to crack it open that i know of...and its really not that bad. You dont even need the dremel if it really scares you...it just makes the job 100 times easier. And you dont even cut it all the way around with the dremel....just a teeny tiny bit to get a screw driver in there.
Check out the how-to right above this post....its exactly what you need
Old May 10, 2007 | 09:52 PM
Rally@StanceDesign
pics
Tinted lense with tamiya tint spray
Taillight open....you can then remove the chrome and lense separately and paint either one
Old May 10, 2007 | 09:59 PM
koogzah's Avatar
koogzah
So would baking them a bit make the prying-off-the-lens part easier?
Old May 10, 2007 | 10:02 PM
koogzah's Avatar
koogzah
It also might get you in trouble with Johnny Law.
Old May 10, 2007 | 10:15 PM
Rally@StanceDesign
Presumably...its not really necessary though. The dremel method takes no time at all. I bet you could even just leave it out on a really sunny day or take a heat-gun/hair dryer to it and not risk warping or anything.
Old May 10, 2007 | 10:16 PM
n1ftyneil's Avatar
n1ftyneil
Is it easy to seal them up again NEATLY? Thanks so much for the help. I have not read the instructions so I probably should, I just thought I'd ask!
EDIT: Great write up, thank you very much!!!
Old May 10, 2007 | 10:28 PM
Rally@StanceDesign
I havent re-sealed them....that pic was just a test fit. The other guy who did the write-up did reseal them though...so check it out
Old May 11, 2007 | 07:15 AM
pobsey's Avatar
pobsey
I've done this as well,
Old May 11, 2007 | 08:29 AM
Rally@StanceDesign
What did you do with the chrome? Paint it red? Can't really tell in that pic. Looks good and clean
Old May 11, 2007 | 08:47 AM
pobsey's Avatar
pobsey
Rubbed it off with metholated spirit and some cotton wool
Old May 11, 2007 | 08:49 AM
Rally@StanceDesign
And then what? Just left the plastic? What color is it?
Old May 11, 2007 | 08:52 AM
pobsey's Avatar
pobsey
The facelift lights are different to the pre facelift lights, as the chrome part of the facelift light is the same piece as the coloured lens, so its translusent red with the chrome removed, I did think about painting it body colour but it proved too difficult to mask it off..
Old May 11, 2007 | 11:21 AM
MCDriver's Avatar
MCDriver
pobsey,
what "grade/weight" steel wool did you use?
i assume that you had to "crack" the casing of the tail-light assembly in order to get to the chrome, and then re-assemble the halves.
Old May 11, 2007 | 12:01 PM
pobsey's Avatar
pobsey
Originally Posted by MCDriver
pobsey,
The chrome is that fragile it comes off with just cotton wool and meths, I just used some cotton wool pads women use to remove make up
Your correct about popping open the light and resealing it, I used some black bodyshop glue - normally used to stick spoilers on, with it being black it also acts as a filler for the dremel cutting disc groove
Old May 11, 2007 | 04:01 PM
n1ftyneil's Avatar
n1ftyneil
WOAh, cool! So my 05 is going to have red translucent plastic under there?
If so, I'm going to Home Depot and buying a Dremmel tonight!
Are the actual lights a piece of cake to get out? The write up doesnt talk to much about it.
Thanks for getting the creative juices flowing guys!
N
Old May 12, 2007 | 12:50 AM
pobsey's Avatar
pobsey
Yep you will have translucent red under the chrome,
To get the lights out is just one nut, think its a 8 or 10mm, you'll need a ratchet to undo it but its easy,
