ScangaugeII gauges and pics
Old Aug 25, 2010 | 09:54 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
So we've been selling the ScangaugeII for 3yrs now. Personally we think it's the best and simplest gauge you can get for your MINI. But alot of customers ask us where they should mount it and what gauges to set it for. So I thought I'd see if the NAM members could post a pic of it mounted in your MINI, and list the 4 gauges you have it set to display.
My DD MINI has one and is set for:
1. Corrected Mile per hour
2. Coolant temp
3. Intake air temp
4. LOD, sometimes I change it to HP just for fun.
Old Aug 25, 2010 | 10:17 PM
Tmini08's Avatar
Tmini08
Gauges displayed:
1. Correct miles per hour
2. Intake Air Temp.
3. Water temp.
4. Miles per gallon
And yes I purchased from Way Motor Works. Thanks for the fast delivery.
Old Aug 26, 2010 | 12:18 PM
NightFlyR's Avatar
NightFlyR
I have mine mounted on the left side of the Tach, you can somewhat see it in my avatar here.
I have it set for
MPH
Intake temp
Water temp
Volts
and of course the Color is set to blue so it is a near perfect match for my Blue LEDs and Trim rings, will try and get a better picture tonight
Old Aug 26, 2010 | 01:07 PM
Achilless's Avatar
Achilless
Subscribed
Old Aug 26, 2010 | 01:40 PM
beken's Avatar
beken
I have mine mounted on the dash in the left corner. Display color matched to the dish display.
I show Boost, Ignition timing, Water Temp and Intake Air Temp.
Old Aug 26, 2010 | 03:30 PM
Achilless's Avatar
Achilless
question or those who have them, do you take them out of your car ever because of theft? I have had a gps garmin stolen.. I'm just wondering. I'll be gettin the scangauge from wmw soon
Old Aug 26, 2010 | 04:40 PM
Minidrivr's Avatar
Minidrivr
Water Temp
Voltage
Intake Temp
Boost
Mounted with velcro in the cubby hole in front of the cup holders. Never removed it for theft since it's hardly noticeable down there outside the car.
Old Aug 26, 2010 | 05:06 PM
scottab36's Avatar
scottab36
AFR
IA
Water Temp
True Speed
Old Aug 26, 2010 | 05:24 PM
trwxxa's Avatar
trwxxa
Craven Speed mount on the right of the tach.
Correct MPH
MPG
Water Temp.
Volts (sometimes LOD or HP)
Pics coming soon.
Old Aug 26, 2010 | 05:41 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
If you are worried about theft, just double face tape it to the bottom of the toggle bank. It would more difficult to see there and the wire easily hides behind the knee bolster panel under steering wheel.
Old Aug 26, 2010 | 05:50 PM
BamaCooperS's Avatar
BamaCooperS
Craven Flexpod Mount (ScanGauge shifted far right and held with moulding tape).
Boost
Voltage
Water Temp
Intake Temp
Old Aug 27, 2010 | 01:38 AM
NightFlyR's Avatar
NightFlyR
I never take mine out
Old Aug 28, 2010 | 11:49 PM
CZ Mate's Avatar
CZ Mate
Scottab36 - So the scanguage does Air/Fuel Ratio? I see that in the description.
Old Aug 29, 2010 | 04:26 AM
scottab36's Avatar
scottab36
Yes it does. I wouldn't do a DYNO to with it but it's probably close. It's wide-band and the sticky link is here for AFR and others:
https://www.northamericanmotoring.co...ml#post3099619
Old Aug 29, 2010 | 04:43 AM
ChrisNJ's Avatar
ChrisNJ
I put mine in the cubby with a few pieces of velcro. I set water temp, AI, Lod, VLT. It is fantastic.
Old Aug 29, 2010 | 04:53 AM
michele r53's Avatar
michele r53
I'm picking one up after I come home from Italy I'm looking for some ideas on mounting also
Old Aug 29, 2010 | 10:08 PM
colton1237's Avatar
colton1237
Do not have any pics currently, as for the guages displayed:
2. RPM's
3. Water temp.
4. Miles per gallon
Old Nov 21, 2010 | 09:02 AM
VelvetFoot's Avatar
VelvetFoot
I used cable ties.
The unit can be flipped out of the way if necessary.
The cable can be routed unobtrusively.
I'm sorry I didn't think of this when I had XM radio.
The XM receiver was just about the same size as the SG.
Old Mar 24, 2012 | 08:30 AM
RobMuntean's Avatar
RobMuntean
I am wondering is this scangaugeII good for a 2011 MCS? and is it easy to install?
Old Mar 24, 2012 | 11:48 AM
DR61's Avatar
DR61
I recently installed one in our 2012 R60 ALL4. Works great!
Old Mar 25, 2012 | 10:55 AM
hamptup's Avatar
hamptup
Thanks for confirming, it's now on the mod list!
Old Apr 5, 2013 | 05:56 PM
ASKtheteach's Avatar
ASKtheteach
I got my 2012 Countryman 3 weeks ago, and put a ScanGauge II into it last week. Displays Voltage, Coolant Temp, Intake Temp, and Fuel Economy (until I can figure out how to make it read Oil Temp or Pressure). I mounted it on the dash near the lower left corner of the windscreen. Lighting matches the stock gauge lighting.
Filmy
15
Jun 6, 2023 06:27 AM
Oct 19, 2015 08:07 PM
Klenk
GP Talk
Sep 16, 2015 11:29 PM
Gen1Parts
Sep 7, 2015 01:37 PM
