How To Interior/Exterior :: Replace mirror covers (WITHOUT breaking the clips!)
Old Apr 8, 2011 | 04:14 PM
  #126
BenjaminRoystan's Avatar
BenjaminRoystan
Huge Help
This was exceptionally helpful. Thank you!
Old May 3, 2011 | 02:31 PM
  #127
MINIng's Avatar
MINIng
Pulling the mirror cap was a commitment thing. Almost thought that I was going to break the mirror in half, but the man was right. Violent, but right.
+100
Old May 26, 2011 | 12:56 PM
  #128
UT_Evo's Avatar
UT_Evo
So where's the guide for 2nd gen MINIs? The R56s?
2007+ Cooper and Cooper S to be exact...
Old May 27, 2011 | 09:08 AM
  #129
UT_Evo's Avatar
UT_Evo
No one?
Old Jun 5, 2011 | 05:40 PM
  #130
Mini Fireman's Avatar
Mini Fireman
They're easy. Just pry them off gently with a plastic trim removal tool.
Old Jun 19, 2011 | 09:10 PM
  #131
tilzey's Avatar
tilzey
I'm in the dark - what is a plastic trim removal tool?
IOW, where does one get such a thing?
Any other more common items that may work as well?
Thanks!
Old Jun 19, 2011 | 09:16 PM
  #132
tilzey's Avatar
tilzey
FYI - re: photos with explanation about changing the R56 side mirror covers.
http://www.mini2.com/forum/second-ge...hange-how.html
Old Jun 25, 2011 | 04:45 AM
  #133
Mini Fireman
Thanks!
Google is your friend. Try it some time instead of asking for help.
Googled trim removal tool & got this as the first pic (what I use, although not a VW tool):
Got this as the first link: http://www.amazon.com/NESCO-Removal-.../dp/B000HSJE34
You can buy the pictured trim kit at Harbor Freight for a few dollars.
As for that MINI2 link, you don't have to bother with the using the screwdriver to go between the mirror & cap to release the tabs on newer MINIs. Just gently pry between the top edge of the cap & the black mirror surround until it pops off then work your way around the cap until enough tabs release to remove the cap..
Old Jun 25, 2011 | 07:26 PM
  #134
tilzey's Avatar
tilzey
VERY easy, but pleased I asked
We have two 2009 MC Hatchbacks, both waiting for new side mirror covers.
I had both sets ready, instructions I had printed from NAM, plastic knives, a blanket for the floor, and some trepidation.
And changing the side mirror covers was SO EASY that I laughed out loud!
I used a very thin screwdriver and very, very carefully, starting at the top, pried inbetween the cover and the mirror molding.
I worked on the top and it popped loose, then the outside edge. A bit of working the bottom loose and the cover was off.
IN SECONDS.
Then, the new cover went on in a blink. Lined it up and pushed it on.
The second cover change was even quicker.
No need to remove a mirror or anything like that with the R56.
I suppose you could fiddle around with the mirror, but the mirror has nothing to do with removing the cover on our two R56 MCs.
So, you don't have to amp up your courage to change the side mirror covers on the R56. Just read the simple directions, have whatever thin tool you are confident with, and change those covers in just a couple minutes.
On the other hand, I will be happy to do it for your for less that the MC dealers - how about only $75.00 for a set.
Old Jun 25, 2011 | 07:34 PM
  #135
tilzey's Avatar
tilzey
Mini Fireman was right
Per Mini Fireman: "Just gently pry between the top edge of the cap & the black mirror surround until it pops off then work your way around the cap until enough tabs release to remove the cap.."
YES!
What he said!
Old Oct 24, 2011 | 03:04 PM
  #136
CZ Mate's Avatar
CZ Mate
Great forum.. First one went great.. Than I got on the driver side and cracked my mirror. Does anyone know if you can just by the mirror? Of so how much $? & where should I get it from?
Old Oct 24, 2011 | 03:27 PM
  #137
CZ Mate's Avatar
CZ Mate
Well just called the dealership in portland, $69.68 for heated glass piece. FML.... All for $25 used mirror caps I was going to use as a project. I hope I can find the glass cheaper online
Old Mar 19, 2012 | 02:32 AM
  #138
Mini Me 40's Avatar
Mini Me 40
Hi, tried it you way, unless i had fingers thinner than razors i didnt stand a chance, so i tilted the electric mirror up an popped off the clips with a long pair of scissors then did the same with the top, hey presto mirror cap dropped on to the towel. i cant afford £75 on new caps so i chequred them myself with the left overs from my bonnet i did, LOOKIN GOOD and cost me next to nothing!!!! wahoooooo
Old Mar 19, 2012 | 02:35 AM
  #139
Mini Me 40's Avatar
Mini Me 40
Hi i tried it your was but unless my fingers were as thin as razors i didnt stand a chance so i tilted mirror up an popped off the bottom clips with a long pair of scissors, did came with top, brill it dropped on to the towel without any broken clips. i cant afford £75 for new checkered caps so i did them myself with leftover checks from my bonnet, they look stunning and cost next to nowt lmao !!!
Old Apr 13, 2012 | 06:45 PM
  #140
wvmtnbiker's Avatar
wvmtnbiker
A world of thanks!
ImagoX you are the king. I thought I would have to take her to the dealer to get my new union jack mirror caps on. But thanks to you, I had both of them installed in <10 minutes. Yippee. YaHoo.
Now she looks even more British than ever. It's forums like these that help people and this is one happy Mini owner.
Attached Thumbnails Interior/Exterior :: Replace mirror covers (WITHOUT breaking the clips!)-dsc05471.jpg
Old Oct 5, 2012 | 10:24 PM
  #141
willieboy's Avatar
willieboy
Once again I search for a solution and NAM has an answer. Thanks for posting this. I will use this on Sunday. Need to send my caps out for new paint. Thank you again.
Old Oct 27, 2012 | 07:58 PM
  #142
willieboy's Avatar
willieboy
Ordered up some new mirror caps and sent them to the paint shop as mine were scratch pretty badly. Only down side was the last dumb azz siliconed them on. I can't stand hack jobs. Took me a half hour to remove the right mirror cap. I hate it when that happens. Thank again for the tips. They did help alot Now it's on to the left.
Old Oct 27, 2012 | 08:14 PM
  #143
willieboy's Avatar
willieboy
Normal installation on the left hand side. Five minutes max. No silicone hack job. Thanks again for posting this. VERY helpful
Old Mar 22, 2013 | 11:52 AM
  #144
silveradoboomer's Avatar
silveradoboomer
Worked great first time I tried it on my 2007 Oxygen Blue with new checkered mirror caps.
Thank you ImagoX
Old Nov 19, 2013 | 07:39 PM
  #145
tarynlittlebit's Avatar
tarynlittlebit
Spiders and hornets!
On the positive side of things: just did this to remove my mirror caps and paint them a different color. Super easy and took maybe two or three minutes.
Unfortunately…I found a mama her many baby spiders on the inside of the mirror cap on the passenger's side and a hornets nest on the drivers side… Luckily, I got some gloves after the spider discovery before taking on the hornet.
Old Dec 3, 2013 | 01:54 PM
  #146
mikey_t's Avatar
mikey_t
Worked very easily with my 2011 Countryman. Released the two bottom clips first with a long thin screwdriver and the plastic trim removal tool to carefully pry back the bottom of the cap, then released the inside top & used the trim tool to pop the other two free. No broken clips & it took about 10 mins to do both sides.
Old Feb 25, 2014 | 05:54 PM
  #147
winstonsiraj's Avatar
winstonsiraj
Awesome! Worked like a charm
Great post, thank you!! Saved me money from going to the body shop. Literally took 5 minutes to take off mirror, pop out the cap and replace. oh, and I remembered step one to put down the towel my cap did pop out. Thank you!
Old Jan 22, 2016 | 07:56 PM
  #148
serega12's Avatar
serega12
Am I the only one that got a crack down the center of the mirror vertically? I thought I followed the instructions carefully...
Might be cold weather...
Old Apr 8, 2016 | 08:57 AM
  #149
aabcds's Avatar
aabcds
I just used this method and it worked great! Only took a few minutes to switch out the caps.
Old Jul 4, 2017 | 04:30 PM
  #150
RllyDrvrIX's Avatar
RllyDrvrIX
Perfect!
Both mirror caps changed in under 10 minutes, no broken mirrors or tabs!!!!
Many thanks to the OP!
