How To Maintenance :: Oil Change How-To
Old Jan 5, 2009 | 03:55 PM
  #176
Crashton's Avatar
Crashton
The only way I see of changing that bonded on gasket would be to replace the drain plug. Not something I've done unless the hex is getting borked.
Now I believe the R56 uses a crush washer that has to be replaced at every change.
Old Jan 6, 2009 | 12:03 AM
  #177
cmy's Avatar
cmy
Originally Posted by Crashton
Your coolant leak most likely is the thermostat housing. According to the tech I talked to, they all do it & it is an easy fix. Fret not you still have warranty coverage.
That is good news. Hopefully that is all it is. I take it in on Wednesday morning, so I should know something shortly thereafter. This will be my last trip to the dealer under warranty, so I'm hoping they look it over for any additional problems. The service advisor is a nice guy and goes out of his way to make people happy. Hope this hasn't changed since my last visit
Old Jan 6, 2009 | 10:03 PM
  #178
not-so-rednwhitecooper
I buy an oil filter and a drain plug for every oil change at Classic. Its only a $3 part.
Ive always been told to replace the gasket or washer on the drain plug with every oil change, and I still do it either way.
Old Jan 7, 2009 | 06:42 AM
  #179
DixonL2's Avatar
DixonL2
The mini drain plug is crap. The integral rubber washer can swell after time, and a 13mm head gets "borked" (love that word) very easily, especially if the rubber washer swells and/or the plug ends up gorilla-tight.
I replaced mine with a VW plug - the kind used from 1980-1996 or so (same threading, a whopping-big 19mm head that's about impossible to "bork", and a replaceable copper crush washer). I ground the VW plug down to the same length as the Mini plug just to be overly cautious, and super-cleaned it after grinding. I may use an oil-resistant rubber washer next time - we'll see. I had borked up the Mini 13mm head, even carefully using a 6-point Craftsman socket/handle after the previous mechanic (not me) overtighened the plug.
MAKE SURE NOT TO OVERTIGHTEN! 25 ft-lb (or 19) isn't much - it's tight-but-not-gorilla-tight with a 6" wrench, but if you're using an 8" wrench you're overtightening. You do NOT want to mess up the threads in that painfully-expensive ribbed aluminum oil pan.
Other than that issue, it's a relative pleasure to change oil in the Mini. The canister filter means about zero for the "messiness quotient" (if you break vacuum, then let it drain 5 minutes, then remove), and I can get at the drain plug even with the skidplate on. I use a small piece of "just-in-case" aluminum foil, shaped to direct oil away from the skidplate, but have never really even gotten foil oily. (say that 5 times fast). May go to a Fumoto drain valve sometime, but with the VW plug installed it's likely unnecessary. I can undo a 19mm plug every 5k and put the $25 toward Motoring fuel.
Old Jan 7, 2009 | 01:27 PM
  #180
Crashton's Avatar
Crashton
I'm thinking the rubber gasket gets squeezed & acts as a lock washer. I believe this compounds the bork factor.
That's a good tip on the VW drain plug. Now if one uses an R32 drain plug is it better than a GTI one.
Old Jan 7, 2009 | 03:56 PM
  #181
You know, Autozone sells a replacement drain plugs that use a replaceable plastic washer.
I bet the have one for a MINI, its a rather common drain plug thread size.
Old Jan 7, 2009 | 04:35 PM
  #182
Crashton's Avatar
Crashton
Maybe when I run out of my supply of oem ones I'll get one.
Old Jan 7, 2009 | 07:30 PM
  #183
DixonL2's Avatar
DixonL2
The VW plug was maybe 1/8" longer and, having never seen the innards of the Mini's oil drain pan, I opted to grind 'er down to length. Most probably not necessary - and if not, there are VW drain plugs with really strong little magnets in 'em - a neat little add-on that's likely not necessary, but cool to think about. That's how I got the spare, there's a magnet in my wife's cabrio's sump plug, and the mini has the old one.
Good tip on the Autozone replacement - but both they and PepBoys don't carry a Mini replacement due to the integrated washer, and wouldn't match to thread size. A little research (basically, finding out both the VW and Mini use the same Fumoto plug SKU number) led me to the VW plug.
Old Jan 7, 2009 | 11:15 PM
  #184
Eric_Rowland's Avatar
Eric_Rowland
I got a 14x1.5 drain plug, with plastic washer, at NAPA when my $(#^% OEM oil temp sender stripped the (first three) threads out of my oil pan.
Old Jan 8, 2009 | 05:04 AM
  #185
Capt_bj's Avatar
Capt_bj
common oil drain plug
The Fumoto F-106 is a very common size .... implying the MINI is too
for complete list see
http://www.fumotousa.com/
IMPORTS PART #
Audi 80/80 Quattro('88-'92), 90/90 Quattro('88-'91), 100/100 Quattro('89-'91), 200/200 Quattro('89-'91) F-106
90/90 Quattro('90-'91 20 valve), 100/100 Quattro('92-'94), 200 Quattro('90-'91 20 valve) T-207
V8 Quattro('90-'94), A8/A8 Quattro('97-on) FG-8
S4('92-'94), S6('95-''97), Cabriolet('94-'98), A4/A4 Quattro(4 cyl.-upto '96), A6/A6 Quattro('95-'96) T-207
'97 & on, A4/A4 Quattro(4 cyl.) & TT(1.8L Turbo)--- *Require adapter ADP-207 due to recessed plug T-207*
S4('00-on), S6('01-on), A4/A4 Quattro(V6), A6/A6 Quattro('97-on), Allroad('01 & on) F-106
All other models F-106
Acura All V6 engines('96 & on oil pans with recessed plug require adapter ADL-106) F-106
All 4cyl. engines('99 & on oil pans with recessed plug require adapter ADP-106) F-106
Honda All models up to 1983 F-105
'98 & on, Accord(4cyl.), Prelude, S2000 require adapter ADP-106) F-106
'96 & on V6 engines require adapter ADL-106 F-106
All other models from '84 & on F-106
Hyundai All models F-106
Isuzu 2x4 Pup engines & 4BD1 truck engines F-105
89 - '91 Trooper II F-107
All other engines F-106
Jaguar '98 & on, V8 engines F-106
'00 & on, V6 engines F-107
Kia All models. ('00 - on models require adapter ADP-106) F-106
Lexus All models F-103
Mazda All models except '95 & on Pickups (see Ford applications for '95 & on pickups) F-106
Mercedes 560SEL, 560SEC, 500SEL, 500SEC, 450SEL, 420SEL, 400E, 380SE, 300SD, 300D(up to '85) F-109
300TD(up to '85), 300CD, 240D, 280E, 280CE, 280SE, 190D(2.2-up to '84), 190E(2.3-up to '84) F-109
560SL, 450SL, 450SLC, 380SL, 380SLC T-207
350 SDL, 300TE, 300SDL, 300SE, 300SEL, 300D('87), 300TD('87), 300CE, 300E, C280, 260E F-106
190E(2.6 & 2.3 - 16), 190E(2.3 - '85 to '93), 190D(2.5), 190D(2.2 - '85 to '89) F-106
All other modesl from '86 & on F-106
Mini Cooper '02 & on, all models F-106
Mitsubishi All models('01 & on Montero requires adapter ADL-106) F-106
Nissan All models from 1990 & on F-103
Peugeot 505 Gas Turbo F-105
307XS F-106
All other models F-108
Suzuki All models F-106
VW Eurovan('92 - '99 4cyl., 5cyl. Gas/Diesel engines) T-207
'98-'99 1.8L Turbo(Passat)--- *Requires adapter ADP-207 due to recessed plug T-207*
All other water cooled engines('99 & on oil pans with recessed plug require adapter ADP-106) F-106
Adapter required for oil pans with recessed oil plug.
Old Jan 8, 2009 | 05:53 AM
  #186
DixonL2's Avatar
DixonL2
Good call, Captain! Using my little Powerbook's "find" function, I see 21 other F-106 Fumoto entries in the above.
(Crashton: The preferred VW plug is from the 1990-92 2.0 liter 16V engine... that's what I had in my '91 GTI and 1990 small-bumper GLI. The plug from a 2.slow won't work. Oh, it'll fit and seal up just fine, but it makes the motor slower just by being there! )
Actually, some VW motors use a different plug (see above), don't know about the R32, but if it fits that plug WOULD make the car go faster. Add some vinyl and blingin' rims and NOBODY would catch you.
Old Jan 8, 2009 | 06:49 AM
  #187
Capt_bj's Avatar
Capt_bj
and 17 more on the US car page...some models of each of the big 3
Old Jan 11, 2009 | 04:37 PM
  #188
cmy's Avatar
cmy
It was the thermostat housing. Replaced and all is well. The oil leak was the valve cover gasket.
All replaced under warranty
Old Jan 12, 2009 | 04:17 PM
  #189
MrDimple's Avatar
MrDimple
All you guys are on the right track! Just wanted to mention we manufacture and sell the strongest drain plugs made specific for minis, check us out. We are here to help. We ship every Dimple plug with 2 new copper reusable washers which should last you for years. Put a dab of anti seize out of the tube onto the drain plug threads and torque or use common sense with a six inch wrench and life is good!! Good luck.
Old Jan 18, 2009 | 02:24 PM
  #190
minionthehill's Avatar
minionthehill
Randy, I wish I could send you a photo of how much oil spilled all over my garage floor after reading your directions. You would clearly see NOT A DROP!
Dude your oil change primer was perfect! I also appreciated the "lessons learned" from the others. Paricularly helpful was allowing the filter canister to come out 1/4 inch, and then wait 5 minutes. No spill whatsoever!
Thanks for your effort on this one.
JD
Old Jan 21, 2009 | 05:36 AM
  #191
DixonL2's Avatar
DixonL2
Yet another case where 1/4 inch made ALL the difference!
Old Feb 14, 2009 | 12:21 PM
  #192
adrianr's Avatar
adrianr
ok, i did all this hahah i had a lot of trouble putting the filter back on i put back on with my hands and i thought it already was tight so i turned the car on and the oil started comming out $@#% so i took it out i saw that the rubber band that was new was thinner so i had to put the old one back and use a wrench to put back the filter which was really hard to take out and to put back in because the lack of space in the automoatic
Old May 22, 2009 | 01:53 PM
  #193
Nics's Avatar
Nics
Hate to sound like a noob but when wrenching the oil filter canister OFF from the top of the engine bay, do you swing the handle towards the front of the car or towards the back? (I know the saying "lefty loosey, righty tighty" but I am completely stuck since the filter won't budge either way (guess I'm weak, heh))
Old May 22, 2009 | 02:10 PM
  #194
Capt_bj's Avatar
Capt_bj
test your wrench in your hand and the "lefty loosy" is correct ....
the canister CAN be tight and lefty loosy means you're turning toward the firewall if I'm visualizing/remembering correctly. (but once I do a lefty loosy wrench test I just GO with the FLOW)
Unlike any other car I've changed oil on...be prepared to use a wrench to tighten the filter canister as well
Old May 22, 2009 | 02:19 PM
  #195
Crashton's Avatar
Crashton
Counter clockwise. You may have to slip a piece of pipe over the ratchet handle to gain enough leverage.
I've found that the jack handle of my Harbor freight racing jack works well for that. Last oil change on a friends MINI I had to use it.
Old May 23, 2009 | 12:13 AM
  #196
Eric_Rowland
'toward the firewall' only if the wrench is on the right side of the canister. IIRC when facing the engine the wrench tends to be at 120-140 degrees, so I'm pulling away from the firewall...
Old May 23, 2009 | 07:41 PM
  #197
daewoni's Avatar
daewoni
"5 minutes" is the key. I waited about 1 minute and spilled all over the place!!
Old May 25, 2009 | 09:41 PM
  #198
paipuky's Avatar
paipuky
hey if someone need this info, I found it very helpful after changing oil yourself. "How to reset Oil change interval"
If someone else has post it again, well, twice don't hurt.
http://new.minimania.com/web/SCatago...0/ArticleV.cfm
Old Jan 12, 2010 | 03:58 PM
  #199
dubee's Avatar
dubee
Help on the oil change
Randy,
Big thank you on help with the oil and filter change, with your help made the change very simple.
Thanks again.
Dubee
Old Feb 15, 2010 | 06:21 AM
  #200
winnie mini's Avatar
winnie mini
What a great forum
I've had my "Winnie" ('05 MCSc) for about a year, so decided it was time to do an oil change. Had a discount code from Mini Mania so I ordered the Mann oil filter, replacement drain plug and air filter, which arrived quickly and went out Saturday morning expecting to spend an hour or so under/over/around Winnie.
Got her up on the jack stands and crawled underneath to pull the drain plug - and of course it wouldn't budge with the 3/8" ratchet handle, so I got out the breaker bar and proceeded to "bork" (what a wonderfully descriptive word) the head. Tried everything I had in the garage to get it loose, and came back in the house to search NAM for a solution.
10 minutes later I was headed to Home Depot to pick up a set of Irwin Bolt-Grips. Drove the 1/2" tool onto the now-round plug head, grabbed the hex on the bolt-grip with the biggest (18") crescent wrench I had, and finally broke the sucker loose.
Everything was uneventful after that, thanks to the instructions in this thread - thanks Randy.
This was the first time I have tried to get into the air filter, it was easy too - once I figured out that the cover just needed to be slid back toward the firewall to release the clips on the back...
I struggled a little trying to get the cover up high enough to pull the filter, until I decided to remove the intercooler cover, which gave enough room to raise the air box lid and slide the filter out, without having to remove the air hose from the front.
Great forum - I'd never get anything accomplished without you guys
