How To R53 Mini Cooper hydraulic tappets | Fixing noisy rocker arms
Old Mar 14, 2021 | 11:17 AM
Project_Mini's Avatar
Project_Mini
Old Mar 15, 2021 | 10:44 AM
nd-photo.nl's Avatar
nd-photo.nl
Good to know, could you recommend a video on how to determine if you have noisy rocker arms
Old Mar 15, 2021 | 01:40 PM
Project_Mini
If you think that yours might have this issue i would just pull them off and check. It’s a pretty simple job
Old Aug 12, 2023 | 10:51 AM
tterevej's Avatar
tterevej
Help! Broken 'tappet'
https://youtu.be/W4NVK1vLTcM
Greetings,
I really appreciate your video. I replaced all my valves as one of my 3rd cylinder exhaust valves disintegrated a few months back. I was able to take my head off and replace all my valves and reassemble the car. It started right off - which is amazing as I used Mod Mini videos and the sort to guide my work. (Engine work is not in my world!) I had a few knocks and it sounded like what I'd refer to as a lifter. I had replaced the tensioner, so wondered if it hadn't expanded - but that's been confirmed. I then came across your video and it made a lot of sense. The noise is a lot like a slap of the valve. Anyway, in an attempt to move a few of the tappets, I ended up slipping and broke one. It's brittle plastic. (I've been the only owner of my car and thought these parts were metal when from the factory.) My issue now is whether they are available to purchase or do I need to order a whole new rocker arm just to have that little plastic cap - or tappet? Is there a part number for the broken piece?
I've included a photo.
Any help is greatly appreciated.
Thank you!
Attached Thumbnails R53 Mini Cooper hydraulic tappets | Fixing noisy rocker arms-img-2202.jpg   R53 Mini Cooper hydraulic tappets | Fixing noisy rocker arms-cheers.jpg
cld.antique@gmail.com
Feb 5, 2020 05:37 AM
jhiggs26
Dec 19, 2014 06:20 PM
IIIIIII
Nov 26, 2014 07:50 AM
David.R53
Jul 29, 2014 09:09 AM
CRoth
Jul 5, 2010 09:37 AM
