How To Oil cooler/filter housing gasket replacement
Old Mar 24, 2016 | 10:38 AM
  #151
Lex2008's Avatar
Lex2008
Originally Posted by danraabe
I did this repair last spring. It's a P.I.T.A. I removed the intake, and Cat. Then I split the turbo in half removing the cold side (carefully so you don't damage the fins. I also removed the whole plastic intake to the AF.
Now you have some space.
A word to the wise. Take the whole oil filter housing to a machine shop and have them either check it to make sure its actually flat or have them machine it flat so that you have a little more squish when you reinstall it. You will have to move the water reservoir out of the way being careful not to break it. I like bungee chords to hang it from the hood just to let it stay out of the way, but since you are draining most of the fluid out of the radiator removing it is a good idea. (Is it radiator flush time?)
A word to the wise #2.
Replace the oil line, thermostat, and aux water pump while you are down there as well as any water lines that look tired. Make sure you have an oil line that is wrapped in heat reflective material and use new bolts for everything.
A word to the wise #3
Check to make sure your turbo shaft is in good shape. No movement. A machine shop can do this as well. And don't lose the metal gasket that sits between the housing halves. If there is oil in your turbo or the shaft is worn -be prepared (new turbo + new cat)
Good advice bro.
How much did the machine shop charge for that? Might be cheaper to just buy a new one? Or maybe use a straight edge and eyeball it to make sure the original unit isn't warped.
Note that the aux water pump was part of a recall, so if you haven't had it changed, consider it guys.
I would always use new metal gaskets when you put the cat back in place against the turbo. It hurts to pay $12 each time but it aint worth doing it twice to save $12.
Thanks for the advice on the turbo. I didnt split mine, but next time I know. I assume that is also a one time use gasket only?
Old Mar 24, 2016 | 06:12 PM
  #152
danraabe's Avatar
danraabe
Oil filter
The machine shop didnt charge me, BUT i should have asked them to grind off another .001" just to make sure there was enough squish to get a good seal. The bolt pattern is useless on these things and a new piece costs $400~ Avoid that mistake. My housing still leaks which means wasted oil, a constant mess on the floor, hot stinky oil on the engine and another repair in the future. And consider the time. I've learned to do repairs in groups. Fix the problem + preventative maintenance. Goid luck. Report back if i've been helpful. Its more fun to drive than fix stuff! DR
Old Mar 25, 2016 | 07:55 AM
  #153
Lex2008's Avatar
Lex2008
The bolt pattern is inappropriate. They have 43 bolts holding a heat shield for the exhaust manifold but the goddamn oil cooler has 4 tiny misplaced bolt locations. Make any sense? Not to me.
Bro, I had to do this job twice and the dealer did too before I owned the car. Trust me when I tell you that I feel your pain.
Old Mar 26, 2016 | 05:25 PM
  #154
blackprophet's Avatar
blackprophet
guys how did you get that inner shield off the that down bracket comes from the turbo off. outside of taking the turbo off, I'm catching hell. i know you all said it was no walk in the park.
Old Mar 26, 2016 | 05:37 PM
  #155
Lex2008's Avatar
Lex2008
It's got some bolts holding it in place plus a thick metal bracket that helps support the turbo and exhaust manifold. Ya just gotta feel for them bro.
Old Mar 26, 2016 | 05:49 PM
  #156
blackprophet
i think i removed all the bolts holding it, its that bracket in the middle from the turbo that seems to be holding me back...if not do i just wiggle it out once all the other bolts are out...or do i have to remove that turbo bracket one as well... i looked at your posts and i got this far its just the sob is not moving?
Old Mar 26, 2016 | 08:02 PM
  #157
Lex2008's Avatar
Lex2008
I don't recall taking it out, just letting it dangle from above. You probably just need to loosen the nut or bolt holding the bracket from above so you can push it out of the way.
Old Apr 6, 2016 | 10:22 AM
  #158
blackprophet
Guys, i just got the mother of all reach arounds with no vaseline from the dealer. I got all the gaskets replaced just fine. About two months ago i did the dubious timing chain replacement and it went fine so i thought. But car wouldn't start a few days ago so i got frustrated and just had it towed to the dealership. And today he tells me the crankshaft bolt came loose (ironically when i got there it wasn't loose as he couldn't move it) and that he thinks 99% chance i need a head job as there was no compression. it would turn over but not crank. i'm waiting on the quote but i already know its going to be crazy as the mechanic said they have to send it out to a third party to get straightened out. Still owe $7,000 on the damn car and of course its out of warranty. He mentioned new engine and i was like you SOB's are just determined to get that initial money out of me since i didn't let them do the initial work when they diagnosed it the first time. which was the timing chain and damn near all the damn seals down there, came to about $6500 the first time. I know i friction tightened and torqued that bolt the first time right and tight. Any thoughts or ideas from the community?
Old Apr 6, 2016 | 10:33 AM
  #159
Sorry to hear this :(
Did you get a new bolt and torque it to spec with the timing chain ? Or reuse the old one ?
Old Apr 6, 2016 | 10:35 AM
  #160
Lex2008's Avatar
Lex2008
Bro this is bad news. I'm so sorry.
BTW, you need to start a new thread on this topic. It demands its own thread.
Old Apr 6, 2016 | 10:36 AM
  #161
grussell's Avatar
grussell
Send it out to a third party? I think you need a second opinion from an independent shop.
Old Apr 6, 2016 | 04:46 PM
  #162
blackprophet
It was the existing bolt i used but i'm pretty damn sure i tightened it to spec or at least tightened the hell out of it. Just heard from the dealer and this fool was talking about $8,000 for a head job off the top of this head and then tried to steer me in the direction of a new engine to the tune of about $11,000. Man how did this go so damn wrong. I think i will get that second opinion.
Old Apr 6, 2016 | 04:57 PM
  #163
blackprophet
New thread here in case anyone has anymore thoughts or just chime in with the damn frustration as i am right about now.
https://www.northamericanmotoring.co...ml#post4195288
Old Apr 6, 2016 | 05:06 PM
  #164
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
The chance one takes doing their own work. Cam blocks are required for this job, and yield bolts are torqued to point of snapping off. Dealers do not reuse these bolts for a reason and not a job for a novis and considering the cost of an engine.....well.
It was probably a CAM shaft bolt that came loose....not Crank Shaft.
Unfortunate, pay me now or pay me later situation.
Old Apr 6, 2016 | 05:10 PM
  #165
blackprophet
Well i didn't do it entirely myself. I had an actual ASE certified mechanic doing most of the work. And i bought the cam tool kit to make sure timing was TDC. So i by no means am a novice. What ticks me off with this is they keep saying i did everything right, just the bolt came loose, but again as i said...ironically it wouldn't budge when i went to the shop. again i think they spitballing to recoup what they didn't get before.
Old Apr 6, 2016 | 05:18 PM
  #166
-=gRaY rAvEn=-
Moderator
Have you had the chance to read this yet. May have applied in your case before doing that work.
http://topclassactions.com/lawsuit-s...on-settlement/
Old Apr 6, 2016 | 05:29 PM
  #167
Lex2008's Avatar
Lex2008
Please move your discussion to the newly created thread.
Old Apr 11, 2016 | 12:50 PM
  #168
nkfry's Avatar
nkfry
Originally Posted by Lex2008
Be careful with the Detroit tuned turbo oil line. They gave me some junk banjo bolts that broke in the engine block. I was using a torque wrench.
Sorry that I'm just now seeing this, but the banjo bolts we include in all of our kits are MINI OE banjos. No cheap Chinese hardware included, everything in our kit is either MINI OE, or our own manufactured oil line.
Those bolts are to be torqued to 24 ft lbs, I've never had one break during install.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Apr 11, 2016 | 12:52 PM
  #169
Lex2008's Avatar
Lex2008
Those were not Mini banjo bolts my friend. They were different length, different color, different size holes and way way softer material.
Old Apr 11, 2016 | 12:58 PM
  #170
nkfry's Avatar
nkfry
We have NEVER sold any other option of banjo bolt, our kits have ALWAYS included MINI OE banjo bolts.
We buy them directly from the dealer in mass quantity, in MINI packaging, which has been an ongoing ordeal for over 3 years. And as I said, I've installed hundreds of these kits myself and not once have I had a banjo bolt break.
Phone:586-792-6464
Old Apr 11, 2016 | 01:01 PM
  #171
Lex2008's Avatar
Lex2008
Do these look the same to you?
Old Apr 11, 2016 | 01:08 PM
  #172
nkfry's Avatar
nkfry
That is not the bolts that we stock or ship. We have always shipped our kits out with MINI OE hardware.
I would like to further talk about this, but this is not the place to clutter with garble.
I'll PM you and we can go from there.
Phone:586-792-6464
Old Apr 11, 2016 | 01:12 PM
  #173
neonsteve's Avatar
neonsteve
Agree, the Detroit Tuned kit uses Mini OE high quality banjo bolts and they are strong. I installed their kit and the banjo bolts are an exact match and labeled as OEM. I read on a different thread about someone installing a different brand "upgrade" turbo oil feed line kit from Mini Mania or Out Motoring and the banjo bolt broke. I don't remember what brand the kit was that was mentioned.
Old Apr 11, 2016 | 01:18 PM
  #174
Lex2008's Avatar
Lex2008
I need to apologize for the confusion nkfry.
I just checked my files and I made a mistake and named Detroit Tuned when it was WAY MOTOR WORKS that sold me that kit.
http://www.waymotorworks.com/wmw-sta...-line-kit.html
Again, my apologies. I will correct the original post if it allows me to edit.
Old Apr 11, 2016 | 01:22 PM
  #175
nkfry's Avatar
nkfry
I just checked my fioles and I made a mistake and named Detroit Tuned when it was WAY MOTOR WORKS that sold me that kit.
Apology accepted,
We strive to supply our customers with a quality part, not the lowest price.
Quality is worth every penny and that is why we use OE parts wherever applicable and not cheap bargain hardware.
Nick
Phone:586-792-6464
