How To Heating and Air Conditioning :: Replacing the A/C Compressor Clutch Coil
Old Mar 23, 2021 | 05:37 AM
  #101
Lex2008's Avatar
Lex2008
schweet.
Old May 31, 2024 | 06:42 AM
  #102
ATK666's Avatar
ATK666
IMPORTANT word of caution for replacing AC clutch
I replaced my AC clutch yesterday and now everything is working great; it was 105F outside here in Phoenix yesterday and my AC was blowing at ~45F even when idling, and the compressor engages and disengages without any drama. (I found that my original clutch was a bit rusty and the casing on the power wire had deteriorated, leading to intermittent shorts.) BUT, there's an important word of caution about installing the new clutch that I haven't seen posted anywhere, and the mistake it led to nearly wound up requiring me to buy a new compressor.
The two washers that fit inside the clutch plate before you secure it onto the clutch assembly are not all equal; I'll go further to say not all replacement clutches are equal and tolerances can vary slightly. As I'd read online, I made sure the two washers were inside the clutch plate before I tightened the torx bolt that holds the clutch assembly together. Well, after I tightened the torx bolt it turned out that there wasn't enough of a gap between the pulley and the clutch plate and the pulley wouldn't turn freely, so I had to remove the clutch plate to add another washer or two. This is when the torx bolt stripped and I ended up having to drill and re-tap the mounting spline. It seems to be holding together (a lot is resting on the red locktite I used), but, trust me, this is NOT a mistake you want to make. There NEEDS to be a small gap between the clutch plate and the pulley, and you need to ensure the washers you are using will provide you with a sufficient gap BEFORE you tighten down the torx bolt. I couldn't find the proper gap spec, but the gap I have is ~0.75mm and the AC engages and disengages properly. I would also advise using a hex-head bolt instead of a torx bolt for this job as the torx bolts strip too easily, especially if they get a bit rusty.
I hope this helps!
Old Jun 10, 2024 | 12:25 PM
  #103
ATK666's Avatar
ATK666
Update: Ended up having to replace the entire compressor because my MacGyver fix didn't hold. I tried to re-tap the hole but the bit broke off in the hole and it all went downhill from there! So, all because a .50 cent bolt failed, I had to purchase a new compressor (OEM Delphi), and I decided to replace the condenser that had 19+ years of rock dings in it while I'm at it. I had a mobile mechanic come out this morning to evacuate the system, took off the condenser and gave the radiator a good cleaning with a brush and no-rinse detergent foam. Oh well, the upside is that now I'll have pretty much an entirely new AC system... but it was working perfectly until my MacGyver fix failed!
Old Jun 10, 2024 | 12:28 PM
  #104
Lex2008's Avatar
Lex2008
shiny!
Old Jul 14, 2024 | 11:19 AM
  #105
ghostwrench's Avatar
ghostwrench
I'm glad you noticed the clutch gap. Usually, the specification I find for clutch gap is 0.50mm. This is the same across several different car brands, so I just use it as a general rule of thumb now. As you have seen at 0.75mm, there is some wiggle room in there.
Old Jul 14, 2024 | 12:24 PM
  #106
Lex2008's Avatar
Lex2008
Do you want me to get the correct gap for you on alldata?
Old Jul 14, 2024 | 12:51 PM
  #107
ATK666's Avatar
ATK666
All good! Ended up having to replace the whole compressor.
Old Jul 14, 2024 | 12:57 PM
  #108
Lex2008's Avatar
Lex2008
Understood. Hope she blows ice cold!
Old Jul 15, 2024 | 10:01 AM
  #109
slofut's Avatar
slofut
Love that green!
Old Jul 15, 2024 | 11:39 AM
  #110
ATK666's Avatar
ATK666
Thanks! It's Vvivid "combat green."
Old Jul 15, 2024 | 11:40 AM
  #111
Lex2008's Avatar
Lex2008
combat pea soup...
Old Jul 16, 2024 | 05:43 AM
  #112
slofut's Avatar
slofut
Originally Posted by Lex2008
combat pea soup...
Nah man, I like it! Is that a mini color?
ladsjohn
Aug 9, 2020 01:20 AM
fancy sauce
Apr 16, 2019 01:55 PM
JRhea
May 2, 2015 02:42 PM
fugger
Northern California
Sep 6, 2013 05:19 AM
