How To Maintenance :: Removing Carbon Build-up
Old Sep 2, 2011 | 12:20 PM
texasmontego's Avatar
texasmontego
This is a How-To on Removing the Carbon Build-up, the right way.
I couldn't take it anymore with the decreased performance. My car has 60K miles on it (I bought it with 50K a year ago) and I don't think the carbon build-up has ever been removed properly. The throttle was sticking, the performance was down and it just felt like the car was struggling.
I know there's a lot of people that swear by the Seafoam method, but I've run 2 bottles through my car in 4K miles and it's done nothing. I also got taken for $250 for a dealer method (while the car was in for other service) that was only a temporary fix (a few days and a warm fuzzy feeling).
So, I decided to tackle cleaning the intake ports/valves manually myself. I wasn't going to pay the dealership $$$$ without having some way of verifying it was done right and I just don't trust them. It's my car, if I want it to last, it's my responsibility.
After reading a few posts on cleaning the valves, I didn't see where anyone had done a full writeup on the procedure. I figured I would jump in and do the writeup, so others can do the maintenance, regain the lost performance and learn a thing or two about our cars.
The result? Amazing! I feel like my car runs brand new. The performance is back, the throttle works perfectly and it runs much smoother. I put in the BSH Oil Catch Can after I cleaned it which will definitely help reduce the buildup in the future.
Believe me when I tell you, you can do it. It's not major surgery and only takes a Saturday. I tried to lay out the steps as detailed as possible, for the inexperienced.
If you have any questions, shoot me a PM. Enjoy!
Old Sep 13, 2011 | 11:58 AM
Bulyan's Avatar
Bulyan
Excellent manual. Thanks a lot! I will try on my Peugeot 308 which shares the same engine with R56, no matter some minor differences in air piping. I also suggest using Shumma engine conditioner, an original fluid from Mitsubishi. It was developed specifically to clean valve ports on GDi engines. It makes foam and dissolves gunk and tar without leaking and evaporating like carb cleaner.
Old Dec 28, 2011 | 03:22 PM
countryboyshane's Avatar
countryboyshane
Some small things I've noticed about the guide. You forgot to mention the 10mm bolt that holds the intake manifold inside the engine bay. Also, the screws on the throttle body are T30.
Old Feb 14, 2012 | 11:00 PM
JeffInDFW's Avatar
JeffInDFW
Texasmontego....THANK YOU SO MUCH. This had to have taken you a LOT of time to write up such a detailed guide. The pictures.....Its amazing. The best I've ever seen. Whats really cool is, 10 years from now, some person you will never meet will be in a REAL jam, and will be searching the internet and come across this guide you wrote and it will save their tail. I've already saved it to my hard drive, knowing I will need it someday. Thanks again, and well done.
Old Feb 17, 2012 | 03:24 AM
genik's Avatar
genik
any chance that the carbon buildup might be responsible for AutoStartStop malfunction (not working to be frank) or loss of power/turbo boost over 4000rpm?
Old Feb 26, 2012 | 07:21 PM
onionjello's Avatar
onionjello
I have been experiencing low power and difficult cold starts so i have to Thank you for this excellent "how to"
I used your write-up to perform this procedure on my 07' S just last week and it really made a difference in power and gas milage!! the difficult cold starts remain so it's at the dealer, my guess is the fuel pump is failing, we will se what the dealer says.
I have a small head and so I didn't need a mirror to see what I was doing.
Surprisingly, you did neglect to mention the nut that must be removed from the bottom of the intake as it was the most difficult thing about this evolution due to its near inaccessability as well as being blocked from easy view by the intake.
I only found it after groaping around down there with my greasy hands to try to find out why the intake wouldn't come out.
Old Mar 22, 2012 | 06:03 PM
frankida's Avatar
frankida
thanks... dealer is charging $500 to do the walnut cleaning... I can't accept that kind of cost in good conscience.
Old Apr 4, 2012 | 09:05 AM
4xAAA's Avatar
4xAAA
I haven't done this yet, but your write up certainly lends courage to attempt it. You should consider a side job in technical writing.
Christmas Eve would be so much happier if others had such skill. Santa has wall tested many a toy with "some assembly required".
Old Apr 19, 2012 | 01:56 PM
Chris(CA)'s Avatar
Chris(CA)
question
Hi there,
I'm new to the forum. But I have dealt with carbon on valves and ports before and have lots of experience.
Can you describe what builds up on the valves? When I have removed carbon from the back side of valves in the past the carbon was very hard and baked on; it required a wire bit on a drill or chipping away.
For something to be removed with a toothbrush it must be very soft.
Chris
Old Nov 9, 2012 | 04:19 AM
avuton's Avatar
avuton
Wonderful manual. Wish there were more of these. With that said:
I've never done this fix, and have hardly worked on my MINI, but as a mechanic, I really dislike step #12. There must be a better way. I'm not sure, but maybe something like: Putting the car in gear (1st?), jack up the front, then spinning the front wheel manually? I'm also a guy who refuses to do maintenance with anyone else.
Dec 23, 2015 10:36 AM
greekzilla
Aug 23, 2015 03:44 PM
minipopkart
Aug 13, 2015 05:22 AM
DWooderson
Aug 10, 2015 09:12 AM
