How To Interior/Exterior :: Secure side scuttles
Old Sep 11, 2010 | 05:53 PM
slimjimtell's Avatar
slimjimtell
Occasionally I take my MINI to the touchless car wash and on several occasions one of my side scuttles comes off. Thank goodness I have not lost one, although twice I have left and didn't know it was missing until I got home. Again, thank goodness it was still there and no one had run over it, nor was it damaged.
I decided to take matters into my own hands. I came up with a very easy way to secure them without drilling and without making it permanent, just in case I may want to change out my scuttle to some new flavor.
The fix...HOT GLUE!
It only takes one pea sized bead and voilà it's secure.
All I wanted to do was keep it from sliding off, so one strategically placed pea sized bead and it doesn't slide out, NOR is it permanent.
If you want to remove the bead, simply get a pair of needle nose pliers and pinch the hardened bead and pull it out. Simple as that, no glue residue, no drills, screws and best of all it's on the back side where you can never see it.
See picture below where I put the bead. There are two other spots you can put it as well and it will also work. You're only trying to keep it from sliding off, no need to go crazy and and goop it up.
Old Jan 3, 2011 | 03:45 PM
automan21's Avatar
automan21
hey how do you get that black peice off? I tried to slide it forward towards the engine like the manual says but it doesnt slide. I dont wana force it or break it either.
Old Jan 7, 2011 | 06:14 PM
slimjimtell
You have to really push to get the scuttle holder off.
Old Jan 9, 2011 | 01:20 PM
automan21's Avatar
automan21
thanks got em off and changed the bulbs for the chrome look ones
boostedhaze
Jan 2, 2018 07:26 PM
CM2011RG
Apr 12, 2016 12:44 PM
Ollie625
Nov 15, 2015 06:57 AM
cm.d
Aug 19, 2015 08:51 AM
CM2011RG
Aug 5, 2015 02:00 PM
