How To Interior/Exterior :: LED Door Handle Mod With Pictures
Old Dec 1, 2009 | 09:28 PM
  #51
Soni's Avatar
Soni
sick!! I got to do this to my someday.
Old Aug 6, 2010 | 01:21 PM
  #52
rhcp4life's Avatar
rhcp4life
Kickass!
Old Nov 4, 2010 | 07:41 PM
  #53
joe_bfstplk's Avatar
joe_bfstplk
Originally Posted by rhcp4life
Kickass!
Looks great!
I wonder if I can get British Racing Green LEDs....
C ya,
Dutch
Old Dec 16, 2011 | 10:35 AM
  #54
Hillis24's Avatar
Hillis24
http://youtu.be/r0EXJR1oa4U
Old Jul 4, 2012 | 09:08 AM
  #55
swdsc's Avatar
swdsc
I have no idea what i did wrong i did everything according to this tutorial but my led started smoking right when i connected it :(
Old Jul 4, 2012 | 09:44 AM
  #56
joe_bfstplk
Every electronic part contains magic smoke inside it that makes it work.
My guess is that your LED didn't have a built-in resistor to let it run on 12V and the resulting over-current situation let out the magic smoke.
LEDs drop anywhere from 1.5V to 5V, depending on their color. Shorter wavelengths (blue end of rainbow) drop more, longer wavelengths (red end of rainbow) drop less. I've even seen infrared LEDs that drop as little as 1.2V. So, there needs to be a resistor in line to drop the remaining voltage and limit the current on the LED to less than 20mA.
Assuming a blue LED (everyone seems to be in love with those lately), that means you need 8.6V to be handled by the resistor (5V + 8.6V = 13.6V, which is about what your car sees when charging). This means you need a 470 Ohm 1 Watt resistor, which limits current to 18mA (8.6V / .02A = 430 Ohms; nearest higher standard value, since we want to be *less than* 20mA: 470 Ohms, so 8.6V / 470 Ohms = 18.29mA), wired in series with your LED to keep the magic smoke inside. You really only need a half watt, but I prefer overkill design when putting a circuit together in a hard-to-reach spot....
HTH!
C ya,
Dutch
Old Jul 5, 2012 | 01:49 PM
  #57
Hillis24's Avatar
Hillis24
Yep, you probably didn't have LEDs that were set up to handle the 12v.
I got my leds from oznium.com they have the 12v units ready to go.
boostedhaze
Jan 2, 2018 07:26 PM
xpunisherx
Sep 1, 2015 11:47 AM
wabiker3576
R55 :: Clubman Talk (2008+)
Aug 18, 2015 08:48 PM
minimaximum
Aug 14, 2015 04:05 PM
