How To Audio/Navigation :: Front/Rear Channel Swap
Old Aug 17, 2009 | 12:37 PM
  #401
Robin Casady's Avatar
Robin Casady
Have you played the same piece of music on the MINI?
Old Aug 17, 2009 | 12:51 PM
  #402
schatzy62's Avatar
schatzy62
Originally Posted by jbewley
OK, I've read this entire post and am impressed. I am now ready to do the swap and feel confident that it will work. Thanks to all who made it possible.
Question: I was driving my ford F-350 today and noticed that it had really good seperation between left and right speakers (go figure. I's a farm truck). I could clearly hear drums on one side and strings, vocal on the other. I have not noticed the in my Mini. Is it me or has anyone else noticed this??
Jim
One thing to remember here also is that the MINI is much smaller in size. It is not easy without a second person but measure the distance from your ears to the speakers in the car and the truck you will probably find that the distance on your left side is fairly close. The truck being about 1.05 to 1.15 times the distance of the MINI. but on the right side the distance in the truck is probably more like 1.5 to 1.7 times the distance. This can and will make a big difference in the sound stage if the car has poor speaker quality as well.
Listen to the same piece of music in the truck, your MINI and a friends sedan if you can. You will probably find the MINI has the lowest sound quality. Then do the channel swap and recheck the MINI. It will sound better. Then add some good quality speakers and it will be even better.
Old Aug 17, 2009 | 12:57 PM
  #403
jbewley's Avatar
jbewley
You are right about the size of the "sound stage". The truck is a "cavern" compared to the Mini. Guess this means that the speakers will have to follow this mod.
Thanks,
Jim
Old Aug 17, 2009 | 02:39 PM
  #404
k6rtm's Avatar
k6rtm
Thanks,
Jim
Look on the bright side -- it takes less volume to fill up the space! You need good speakers, but you don't need huge speakers. Nor do you need a huge amp. I'm putting along quite nicely using the OEM head, and the little bass600 bass box -- a very good size for the Mini.
Try things in stages and over time -- I've found the "good enough" level for me.
cheers--
Old Aug 17, 2009 | 03:25 PM
  #405
jbewley's Avatar
jbewley
cheers--
Wise advice k6rtm and I sory I shot you that PM before I finished reading all 17 pages.
I have had my mini for almost a year. I started out only going to do one mod which was a roof graphic. That lead to one more, which lead to one more and so on. Now I have another. I have taken it one at a time, researching fully and will continue to do so. This really is fun as I can do all the things to my mini that I wanted to do to my TR Spitfire, but couldn't afford to. Being retired and owning a mini is a blast. Some have told me I should act my age and look at me funny when I tell that, "I Am".
Jim
Jim
Old Sep 3, 2009 | 04:08 PM
  #406
Mtolleson's Avatar
Mtolleson
Scheisse! What a difference! And so easy. I can't wait to get some speakers in.
Old Sep 11, 2009 | 03:01 AM
  #407
jpmcc00's Avatar
jpmcc00
Help Needed
I managed to get the trim off yesterday in an attempt to do the channel swap... managed to get the wires swaped and then diaster... somehow I managed to break one of the metal connectors which slide into the slots
Now I have great sound on the drivers side and no sound from the passenger side.. question is how do I replace the broken metal connector, I cannot solder it back together as in my rage I lost the other half, can you buy them seperatly from MINI anyone have a part number
Old Sep 11, 2009 | 08:03 AM
  #408
Robin Casady
You can purchase new connectors. Here are the numbers:
Male Pins: 61131376193
Female sockets: 61131376204
Plastic housing for male pins: 61131378137
Plastic housing for female sockets: 61131378139
Available through Pelican Parts, or ECS Tuning
Old Sep 12, 2009 | 02:36 AM
  #409
jpmcc00's Avatar
jpmcc00
Fantastic... thanks for your help
Old Sep 14, 2009 | 09:30 AM
  #410
Dr. Pepper's Avatar
Dr. Pepper
Any tips on removal of the plastic interior pieces? I yank and pull and nothing wants to move. Prying didn't work either. I dont want to break anything.
Old Sep 14, 2009 | 10:20 AM
  #411
Robin Casady
Which pieces?
Old Sep 15, 2009 | 07:57 AM
  #412
Dr. Pepper's Avatar
Dr. Pepper
Originally Posted by Robin Casady
Which pieces?
Those side panels under the dashboard.
Old Sep 15, 2009 | 08:57 AM
  #413
Robin Casady
First pull off the rubber door molding.
The small panel, above the bonnet release, pulls out towards the rear of the car. The lower panel snaps out towards the passenger side.
Old Sep 15, 2009 | 11:47 AM
  #414
lacning74's Avatar
lacning74
My hands are still cramped from working with that connector.
Thought about doing the swap but ended up finally adding a BASS600. I'm constantly adjusting the fade when the kids are in the car and not sure if my brain can handle the switch. Also getting bluetooth in the rear would bug me as well.
With my upgraded fronts, everything sounds nice and full now. Not sure if I'll ever get around to replacing the rears. They do fine filling the soundstage as someone said. I usually set fade to 6 front. Anyway they remind me what progress I made thanks to everyone here whenever I fade completely to rear shutting out the fronts/BASS600.
Old Sep 15, 2009 | 11:00 PM
  #415
MiniLe's Avatar
MiniLe
Originally Posted by eurotrash01
I just did the swap this morning. Not difficult at all, and like tintman718 I used no special tool.
[EDIT- note: I worked on female pins, not male as others have mentioned in previous posts. If you are looking at the schatzy62 picture, you'll see the female pins. My work listed below concerns pressing down on the rims of these female pins with my torx bit in order to get them out of the connector.]
1- Pull out about 2 feet worth of the door liner (it isn't glued in there or stuck in any way. Time taken, 4 seconds)
2- Pull the panel below the hood latch out to right, disengaging it from the frame somewhat. This takes much less energy that it took removing the door panels to replace the speakers last weekend. 2 seconds.
3- The small triangular panel above the hood latch comes out easily by pulling it toward the back of the car. That is the way the attachment tabs work on this piece, so don't pull it to the right as done in the last step. 2 seconds.
4- You'll see the black piggy-backing connector in there with the one we want hiding behind it. Don't bother trying to disengage this black one from the X9331, as you'll simply need to pull apart X9331, freeing the end that you want to work with. Reach in and twist the connectors around a bit. There is a little bit of play room there and you can free up some more space easily. The connector shown in earlier pictures comes out easily once you unclip it from below. It then can be swung back to face you just as you see in the pix earlier in the thread. Orient the thing as explained, with the big brown ground wire (#1 hole) at the upper right. I found that it "wanted" to sit that way anyhow. Time taken...a few minutes to figure it out, and about 20 seconds to do. Done another time it wouldn't take any time at all.
5- With scissors, cut back/pull back 1-2" of the shroud that covers all the incoming wires. This will give you some room to move wires/pins without forcing or bending them. The good news is that this shroud is much more scissors friendly than the shrouds in the doors protecting the speaker wires. Time taken, 20 seconds.
6- KEY STEP. Using a flat-nosed screwdriver for a little leverage between the side of the connector and its base, you want to work around the base of the famous connector (wire end) disengaging the 4 plastic tabs that hold the base in place. As you're doing this, it will "want to" re-seat" itself in place, so keep a bit of pressure in opposite directions on the thing - wire end one way, the end with the 12 holes the other way. What you end up with is the base (holding all pins) pulled out about 3-4mm (only) from the body of X9331. This step allows for easy pin swapping. I thought I'd need to disengage the base more than this at first, but you really only need to go this far. It does not "want to" go farther than this anyhow, so stop there...simply making sure the 4 tabs are all disengaged.
7- Using the torx bit in the hand-held wrench, push down in the holes of X9331 to release the pins. I thought this would be harder than it was, but the previous step really gets you a long way toward simple surgery. Swap them as per diagrams presented here. Make doubly sure the pins are fully back in place (high enough). Push the base back in place clicking the 4 tabs. Re-attach our friend to its host back behind the black-piggybacking connector. I used 2" of electrical tape to tidy up the shroud end a bit where I had cut/pushed back. Twist it all back into place. Time = 2-3 minutes.
8- Slide in upper panel, bang in lower panel getting those door/panel round clips to "pop." Stuff the door liner back in place. 30 seconds.
Take car out for a test. Worked for me. Easy job. No complaints from the wife expected.
I just finished the swap and I have to say...WOW. Didn't think it would make that big of difference. I have the standard Boost stereo. Thank you SO SO much to Wsalopek for providing lots of help. I thought Eurotrash's post that I quoted above was probably the most helpful in terms of steps. I am far, FAR from the best person when it comes to car mods but I was able to complete this in about 35-40 minutes. The hardest part was definitely just removing the panels and separating the connector. The pin swap took about 10 minutes and I used a 5/32 Torx tool on the female end.
Thanks again to all and thanks for giving me the confidence to hopefully attempt my next mod! If you just bought an 07-09 Mini, don't hesitate to do this mod!
Old Sep 15, 2009 | 11:26 PM
  #416
Robin Casady
Unless you have the HIFI option.
Glad it worked out for you.
Old Sep 16, 2009 | 11:25 AM
  #417
cdecker78's Avatar
cdecker78
Does this swap work with the 2009 R55/ Clubman?
Old Sep 17, 2009 | 01:40 PM
  #418
cdecker78's Avatar
cdecker78
So Ive just done the swap and noticed a difference in the bass now that the 6x9s are actually producing some. .. Next step is to figure out a way to install a single 10" and an amp, maybe even replace door speakers and rear speakers. Anyone know how hard it is to change rear speakers in a clubman?
Old Sep 28, 2009 | 01:10 PM
  #419
cheapdanny's Avatar
cheapdanny
After months of procrastination, the swap is complete.... should have done this months ago! Thanks to all!
Old Sep 28, 2009 | 03:00 PM
  #420
Ronin5729's Avatar
Ronin5729
No surprise to anyone here about how much helpful people/info is on the NAM. I've been here about a whole month myself...
I spied a '09 JCW Clubbie last week when I brought in the pre-owned '08 MCSa we bought a few weeks back. It subsequently came home with us on Saturday.
The '08 has the HiFi system and was noticeably "better" (for a complete lack of a better term) than the Boost in the '09.
Then I saw this thread and got it banged out in less than a half hour start to finish (no special tools required, unless you consider Torx bits to be special). I noticed an immediate "improvement" (again, for lack of a better term), which should hold me over until I get the speakers upgraded and a sub in.
For those of you that are concerned, I found the Bluetooth/gong coming out of the rear speakers to be just fine.
Much thanks to everyone who put this tutorial together. This is a must-do mod for those with the Boost stereo, and probably should be a MINI TSB for crying out loud. Actually it's not a mod, it's fix.
Thanks again all!
Old Oct 6, 2009 | 11:33 AM
  #421
jbewley's Avatar
jbewley
Swap was, sadly, unsuccessful. After feeling like I had all the advice from this thread clearly understood, I launched on the project. The two side covers came off with ease, a half rotation of the connector and it was free, pressed on the two side clips and the bottom (female) came lose. Everything went like clock work until I atempted to remove the female pins. All the torx driver was doing was mash the copper edges of the pins and I got no movement. Not wanting to mash anything so it would not re-seat, I put it all back and left well enough alone. Some say the pins ca,e out with ease, so what was I doing wrong??????
Jim
Old Oct 6, 2009 | 01:28 PM
  #422
Robin Casady
Jim
I doubt it was anything you did. I suspect that the barbs on those connectors were just very well dug into the plastic. The real BMW tool (tubing) is supposed to go along the outside of the connector and retract the barbs. However, it didn't seem that effective when I watched k6rtm do it. He had to use a significant amount of force on some connectors when first removing them. Once done, they are easier to remove a second time.
Old Oct 6, 2009 | 01:37 PM
  #423
jbewley's Avatar
jbewley
Good thought Robin. I know some here said they used 5/32 brass tubing, but I thouhgt it was just to push on the edges of the pin, or will that go along the side like the OEM tool? One thing I have learned the hard way is "never force anything" too hard.
Jim
Old Oct 7, 2009 | 06:46 PM
  #424
cheapdanny's Avatar
cheapdanny
I ran into the same situation until I pulled out what looked like an internal plastic wire container within the female connector. Once i did this, the wires popped out without any problems. I used two small flat head screwdrivers and and a small needle nose pliers. Hope this helps.
Danny
Old Oct 7, 2009 | 07:23 PM
  #425
jbewley's Avatar
jbewley
Danny
Can you expand on this a bit? What, when, where and how and why would be very helpfull.
Jim
