one-ball quotes on Hawaii
Old Jul 6, 2006 | 03:31 PM
qweewq12's Avatar
qweewq12
Exhaust Systems Hawaii on king quoted $95 and 1-1.5 hours....
kinda think that is high... should be more like 40-60...
Old Jul 6, 2006 | 04:25 PM
DaKineMINI's Avatar
DaKineMINI
$40-60 are mainland prices so it sounds about right to me.
Old Jul 6, 2006 | 05:28 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
I spoke to a MINI driver that has had the one ball for about 2+ years-
He said it cost about $45 from Exhaust Systems Hawaii- he took it there, they looked at it and he explained what needed to be modified and they said ok and did it. I think if they estimated the cost over the phone without seeing the stock exhaust they might be doing a higher estimate- so take in your MINI and show them it is easy to do- hence worth $45. Plus ESH on King has already done it before.
The benefit of the one ball for the MCS-
Cheap- compared to almost anything else
Loose some excess weight permanently
Sounds better than stock but not loud and doesn't drone
Seems OK on performance- no negative effect, probably MINImal positive effect.
Old Jul 6, 2006 | 05:57 PM
qweewq12's Avatar
qweewq12
actually I did show them... got the before/after pics of the bypass off the NAM site..
however, the bypass they sell online is just $125 for the pipe... so $95 for their "pipe" and install/weld isn't looking so bad...
going to try and get it done before the mini run...
Old Jul 6, 2006 | 11:08 PM
The_Beastmaster's Avatar
The_Beastmaster
Did you try Bobby Barr's in Kaneohe?
Old Jul 7, 2006 | 12:58 AM
qweewq12's Avatar
qweewq12
not yet..I live Kaimuki...
Old Jul 7, 2006 | 03:34 PM
qweewq12's Avatar
qweewq12
got it done today at modern muffler on N. King (close to my work)... $130 & 1.5hrs... took me as a walkin & got busy on it... chopped it... put in a 90 elbow..aligned & tac welded.. dropped the cat back & battery cover, finished the weld... put it back up...
sounds like the reg system.. just a little more louder... gurgling noise is louder, more frequent, and a bit sharper
plus I kinda wanted the elbow to be welded.. not the clamped version mymini sells... pretty much the same as the pic in this thread...
https://www.northamericanmotoring.co...light=one-ball
my resonator is in their muffler pile in the front if anyone wants it...
eliseo1981
Sep 30, 2015 07:57 PM
