overheating?
Old Jan 29, 2006 | 08:01 PM
cwlouis's Avatar
cwlouis
overheating?
hey guys,
my 02 MCS seems like it overheats this past couple of days when i idle too long. i seems like when the AC is running it does that. i also noticed that before this happened, my fan would kick in after i park the MCS (hardly did that before). any thoughs? and since my warrenty expires in sept., i wonder is this covered??:impatient
Old Jan 29, 2006 | 08:10 PM
Rich.Wolfson's Avatar
Rich.Wolfson
Originally Posted by cwlouis
hey guys,
my 02 MCS seems like it overheats...
If the Power Steering pump and fan has never been replaced that is where I would start. Be sure they change the pump and the wiring to add the extra fuse. It's a common problem that causes overheating.
Good luck,
Rich
Old Jan 29, 2006 | 08:15 PM
cwlouis's Avatar
cwlouis
but since i'm under warranty, this should be something they would do?
Good luck,
Rich
Old Jan 29, 2006 | 11:36 PM
Blown-Lone-Star's Avatar
Blown-Lone-Star
has the coolent ever been flushed?
Old Jan 29, 2006 | 11:57 PM
kbseto's Avatar
kbseto
yeah, check out the above stuff...but i believe our cars tend to suck up the coolant fairly quickly also. i check mine at least every month with all the miles i drive weekly. and i think those early model mini's did have some coolant tank recall or warranty stuff done on 'em.
Old Jan 30, 2006 | 12:17 AM
cwlouis's Avatar
cwlouis
i'll check this tomorrow...hope it's just a fill. but i had my tank replaced but never had a flush.. thanks for the heads up!
Old Jan 30, 2006 | 12:44 AM
Tüls's Avatar
Tüls
Turbius Maximus
has the thermostat ever been replaced?
Old Jan 30, 2006 | 06:47 PM
Blown-Lone-Star
yeah the thermostat is a good place to look first. good call.
Old Jan 30, 2006 | 09:17 PM
cwlouis's Avatar
cwlouis
it's resolved. seems like the new radiator had enough coolent when it came out of the shop but not enough (6 months ago). i checked it today, added some 50/50 coolent and she holds! so i even sat in rush hour today just to test it out and it's fine now...so hopefully it was just that.. luckly i had today off (my mental holiday from work ) and figure this out...but thanks for everyones helpful hints!
and i got a helpful hint from my friend who works on chevys...use a black light to check for leaks (toxic green shows up best with a black light)..
Old Jan 30, 2006 | 09:20 PM
RandyBMC's Avatar
RandyBMC
Temporarily Banned
Since you have lost some coolant, and you have an '02, make sure you check your coolant overflow tank - they leak at the seam. If it is white instead of a yellowish color, get it changed before your warranty runs out. The overflow tank is the big plastic tank right in the middle of the engine bay.
Hope that helps!
Randy
Old Jan 31, 2006 | 10:24 AM
JCW04's Avatar
JCW04
Whoa! Nice ride Randy!
silence2-38554
Sep 28, 2015 12:19 PM
rt808
Sep 25, 2015 01:59 PM
rustof
11
Sep 25, 2015 10:35 AM
Tinklespout
16
Sep 6, 2015 11:39 AM
mimaal
Sep 4, 2015 09:09 AM
