Tire pressure light and DSC lights - Glitch or serious?
Old Jan 22, 2004 | 12:12 AM
  #26
erik808's Avatar
erik808
*The_Beastmaster: 39's young!! Dead is old in my book . Those R90s are definitely minihune's . Never forget --> 100% of my posts are 100% fluff
Old Jan 22, 2004 | 12:16 AM
  #27
keikilee's Avatar
keikilee
yah, erik, what's up with that! 817 posts....whoa....in less than 7 months! Yee Haw!
Old Jan 22, 2004 | 12:24 AM
  #28
erik808's Avatar
erik808
^^^ ME POST ***** ^^^
Old Jan 22, 2004 | 12:29 AM
  #29
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Fluff is a good name for a MINI.
I know you were acting dumb
You were probably thinking...
I wonder if MINIhune is asleep at the wheel
I was going to tell you Kohu'ulaMINI had bought my R90s but then his wife would kill him
and then we would need another MA at the dealership.
Old Jan 22, 2004 | 09:25 AM
  #30
riscci's Avatar
riscci
I have had the tire pressure light go off several times. I checked the tire pressure and added/relieved the tire pressure and it worked OK (light went out) after restarting the car.
The problem I see is that the "BUMPS" we hit may in fact cause the depressurization of the tires. This would lead one to assume that the sealing points between the rim and the tire are not as good as those on the "Normal" tires vice those points on the run flat tires.
Old Jan 22, 2004 | 01:29 PM
  #31
Kohu'ulaMINI's Avatar
Kohu'ulaMINI
Aloha and Welcome, riscci
Good observation on the "BUMPS" causing the lights to go off :evil:
_________________
MINIhune:'03 MC VR/VR
Old Jan 22, 2004 | 01:34 PM
  #32
Kohu'ulaMINI
>>"...., and the DSC light goes on when the car doesn't try to plant itself on the ground when a wheel goes off the ground."
..Whooaaahoo!!!!..Are you imitating the stunts on The Italian Job?..
Old Jan 22, 2004 | 01:50 PM
  #33
Kohu'ulaMINI
>>I have a family, house in MINIlani, newish MINI and brand old Odyssey. Does that count? Hey is somebody copying me or am I copying someone else? Can't decide.
I bow down to the ultimate MINI Amdassador, minihune had all his first before I did.
I'm not copying....we just have similar "good" tastes
Old Jan 24, 2004 | 07:19 AM
  #34
erik808's Avatar
erik808
Welcome, riscci :smile:
Old Feb 24, 2004 | 02:57 PM
  #35
mini-t's Avatar
mini-t
back to the original point of this thread...yellow constantly lit DSC light plus tire pressure light at the same time.
i had this same problem on sunday and took my car in yesterday to see if there was anything wrong. sure enough, the lights were on due to a faulty steering angle sensor. the part has been ordered and will be installed in a few weeks.
if anyone else has this problem, it might be worthwhile to bring the car in...
_________________
<a href="http://autos.groups.yahoo.com/group/...join">
<img src="http://us.i1.yimg.com/us.yimg.com/i/...join.gif" border=0>
Hawaii Enthusiasts: click to join our MINI club!
Old Feb 24, 2004 | 03:35 PM
  #36
10851CS's Avatar
10851CS
>>Again, this is a problem on DSC/Runflats equipped MINIs only.
My MCS lights came on after tire rebalancing and I don't have run flats. Push the button and then it should go off. Stop and restart the engine and i'm sure it will go off.
Earl
Old Feb 24, 2004 | 04:09 PM
  #37
mini-t's Avatar
mini-t
yes, this is true for the tire pressure monitor only...but not when the DSC light and tire light comes on at the same time.
>>Earl
Old Jul 1, 2006 | 10:19 AM
  #38
Bugs's Avatar
Bugs
im having this same issue
DSC + low tire indicator.
Ive checked tire preasure, and reset it. Still lights are on.
Im not running runflats, so thats not the problem.
I DO need new brakes. Im wonderring if this is built into the poor brake indicator? My brakes front and rear are SHOT. (warped front rotors + worn out front/rear pads)
any thoughts to this old post
Old Jul 1, 2006 | 10:37 AM
  #39
chows4us's Avatar
chows4us
I had the same thing happen a couple of weeks ago. Accelerating up on onramp to highway, looked down, both lights on. Pressed the tire reset button, drove away, all fine
I checked the tire pressures later and all were OK.
No idea why, I think just one of those quirks
Old Jul 20, 2006 | 07:40 AM
  #40
Coop d'etat's Avatar
Coop d'etat
Same problem here a couple weeks ago, and it ended up being the speed sensor that needed replacement. After the SS replacement I've had no problems. I didn't have any intermitent lights though, once the switch failed the lights came on from the moment the car started rolling. Either way it sounds like a sensor could be bad. I'd make an appointment either way
Terry Gallentine
Aug 11, 2015 03:31 PM
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
