GP rear sway bar size
Old Oct 25, 2013 | 11:51 PM
Wskunz's Avatar
Wskunz
Anybody know what the diameter of the rear sway bar on the GP2?
I have a new NM 22mm bar sitting around that I might throw on if the stock GP bar is smaller.
Bill
Old Oct 26, 2013 | 08:48 AM
gerry2153's Avatar
gerry2153
hmmm since you have it in the driveway you could just measure it. . .
just use a piece of string or tape or . . .
Old Oct 26, 2013 | 12:10 PM
Wskunz's Avatar
Wskunz
Way beyond the age of being able to crawl under there and measure myself, but thanks for the suggestion.
Bill
Old Oct 26, 2013 | 01:35 PM
danjreed's Avatar
danjreed
Bill
Jack up car.
Remove rear wheel.
You can see and measure the bar plain as day.
Old Oct 26, 2013 | 02:03 PM
evoperformance's Avatar
evoperformance
If he said he is beyond the age to bend down and look then I would assume he would be beyond the age to do any mechanical work as well.
Old Oct 27, 2013 | 01:26 AM
k_h_d's Avatar
k_h_d
Bill
I am sure it's smaller but will be interested to find out for sure.
Old Oct 27, 2013 | 07:30 AM
Wskunz's Avatar
Wskunz
I'm sure Way knows, maybe he will chime in, but I will know for sure on Wed when the car goes to Motoring Magic in SoCal for the installation of a set of NM RSe05 17" wheels in red. We will measure it then and maybe install the NM bar while it is on the lift.
Bill
Old Oct 27, 2013 | 07:53 AM
cristo's Avatar
cristo
Alliance Member
I think it's the R56 JCW bar - 18.5 mm, compared to 18 mm for S and 17 mm for regular.
Old Oct 30, 2013 | 10:09 PM
Wskunz's Avatar
Wskunz
We'll we had the car up on the rack for its new wheels today and measured the sway bar with a digital caliper and it measured .670 which is 17mm, a little bit of a surprise that it was so small.
Bill
Old Oct 31, 2013 | 02:32 PM
MiniMoic's Avatar
MiniMoic
Bill
Raally? only 17mm? Interesting. Please share your thoughts one you install it!
Old Oct 31, 2013 | 03:00 PM
akng's Avatar
akng
It's the overall setup that matters. With the suspensions giving extra camber already, I guess they felt that to maintain a balance control for the average driver, it is better to have a sway bar this size. Wider is not always better. If you can't handle it, then it's not better for you.
Old Oct 31, 2013 | 04:15 PM
Wskunz's Avatar
Wskunz
That is what we were thinking so I am going to leave 17mm bar in untill at least the first track day, I don't see any under steer or excess body lean in the corners so this time I will trust the engineers to have made the right choice on suspension components unless I see a need to change. This will be the first out of 7 MINIs we hane owned that I left the suspension alone. We will see.
Bill
Old Oct 31, 2013 | 04:19 PM
MiniMoic's Avatar
MiniMoic
Bill
Ah yes, I agree. If its your first track day in the car, try it, know it. Im past the point where the regular setup is not enough, but you will learn how your own car feels. Then let us know if the bar makes any difference. Or sell it to me!
W0TM8
Dec 19, 2019 07:50 AM
pre shrunk
Aug 18, 2015 11:09 AM
Bennyboy
Aug 18, 2015 07:28 AM
nomar116
Aug 10, 2015 11:24 PM
OutMotoring
Aug 6, 2015 09:32 AM
