which spark plugs to use?
Old Oct 14, 2010 | 02:00 PM
GoodFinder's Avatar
GoodFinder
Time to replace the original plugs. (Well, since I'm at 51K miles, I want to change the plugs, even if just early preventative maintenance.) What plugs are people using in their GP these days?
Old Oct 14, 2010 | 03:23 PM
buzzsaw's Avatar
buzzsaw
Don't know about the GP but this link has more info about spark plugs for the Mini than I ever knew. Good luck.
Old Oct 14, 2010 | 03:49 PM
bahawton's Avatar
bahawton
JCW cars & GP cars use a special plug that's listed on your JCW certificate.
I would tell you what it says but my certificate is at home & I haven't bought plugs recently so I can't remember what it is.
Old Oct 14, 2010 | 08:57 PM
GoodFinder's Avatar
GoodFinder
Thank you for the information and link!
Old Oct 15, 2010 | 03:06 PM
quikmni's Avatar
quikmni
I tried Brisk Silver plugs which worked well but started to run a little bad after about 10,000 miles. As the noted post states, silver is a great conductor but it wears fast. So if you go with silver plugs, plan to change plugs every 10,000 miles. I thought that was a little bit of a pain for the GP since the intercooler has to be removed to change the plugs so I switched back to the stock JCW plugs which are NGK BKR 7 EQUP. The NGK plugs are working well. I purchased mine from Way Motor Works.
There has been various posts on the change interval for the JCW plugs. I have seen posts that vary from every 15,000 miles to 100,000 miles. I changed my first NGK set out at about 30,000 miles and they looked pretty good. I think changing the NGK plugs every 15,000 miles is earlier than probably required for normal driving conditions. I am shooting to change out my current set of NGK plus after 30,000 miles.
eliseo1981
May 10, 2016 05:19 AM
CRC
Sep 14, 2015 07:27 AM
JMF1975
Sep 11, 2015 03:29 PM
rob76turbo
GP Talk (2006)
Sep 7, 2015 12:28 PM
Sep 4, 2015 03:56 PM
