H&R Street Performance Coilovers Installed
Old Jun 30, 2009 | 10:32 PM
leebo's Avatar
leebo
After trying various wheel and tire combinations for GP1512 to get the ride quality where I wanted it, and almost going with Cross Competition Coilovers, I had H&R Street Performance Coilovers installed over the weekend by Danny at MiniCorsa. He also installed the Ireland Engineering fixed camber plates and H-Sport 19mm rear sway bar (set to the middle position/hole).
I am very pleased with the results: More compliant ride with less harshness and chop. The coilovers are very reasonably priced at less than $1,000. I am going to drive it around for a few weeks and take it back for final ride height adjustment and alignment. At first I thought the rear was a little stiffer/lively than I expected, but some of that may have been due to the quality of roads in Danny's area, which are worse than where I live ;-). I took the GP for a quick drive up Mulholland Drive but cannot compare to the stock GP suspension since I hadn't tested that before hand.
Based on my ride in Bryan's (Longboard Mini) MINI with the same coilovers and 215/35x18 Wheels/tire combo, which seemed much better than the stock GP suspension and 16" tire/wheel combo, I will probably go back to the GP wheels after the current tires are worn out. The GP looks best with those wheels.
I have the GP springs and shocks in a box in the garage.
The Out-Pace rear control arms I got with custom spacers didn't fit due to a change from a rubber boot to cup type seals for the rod ends. I might get the spacer width reduced and install when we do make the final adjustments.
Lee
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
squawSkiBum
Oct 2, 2015 09:21 AM
Zettinger
Aug 25, 2015 04:04 PM
