GP NOISE: CAN'T FIND THE SOURCE
Old Nov 26, 2007 | 12:27 PM
  #26
howsoonisnow1985's Avatar
howsoonisnow1985
Originally Posted by Chief_Charlie
lastrega,
Check for a PM
Hey who was your SA? What dealership are you at Mountain View, Walnut Creek/Concord? Any way I just got GP Last nght noticed that same noise as well, I just thought it was the rear tower brace working so well that it pus stree on pillars/chassis. So, I want to go to your same SA since I am In Watsonville/Santa Cruz area
Old Nov 26, 2007 | 02:35 PM
  #27
WC50 408's Avatar
WC50 408
So you bought 0019? Congrats! Another place to check for rattles are the two vents on the inside just beneath the hatch. There is some plastic ducting that gets loose and bumper skin needs to come off to access. Should be covered under warrenty. Btw the way the "rear tower brace" isn't one, just a cargo bar to keep large items from flying into your head when you brake hard.
Old Nov 26, 2007 | 02:57 PM
  #28
Chief_Charlie's Avatar
Chief_Charlie
Another source for noise :-)
GMann has identified another source for noise in the GP (which I also had on mine) Anyway, the sound for this is a definite "plastic on plastic" sound, and the flapper was broken on one of these two cabin venting devices (relieves the air pressure when you close the doors or rear hatch). They replaced one under warranty, and used some felt strips to quiet/cushion both.
The fill-with-foam-to-fix-the-rear-pillar noise is a creaking or snapping sound, only heard when you're just driving slowly around town. It drove me nuts. As you can see from the posts, it took a lot of "detective work" to diagnose, locate, and then fix. The body flexing just slightly caused it.
Old Nov 26, 2007 | 04:37 PM
  #29
Jim Ray's Avatar
Jim Ray
Did you open the storage compartment and take the 4 hard plastic jack blocks out of the car?
Glad to see you made it home ok.
Jim
Old Nov 27, 2007 | 01:08 AM
  #30
howsoonisnow1985
Oh funny I tried to make the noise, did not make it. But earlier I took stuff out to look/use for tool to pull out grill above exhaust so I could put additional reverse light.
Old Nov 27, 2007 | 04:11 AM
  #31
lastrega's Avatar
lastrega
My GP noise, thanks to a collaborative work of Chief Charlie's tech guy and my SA here in MD, has disappeared.
Now, my GyPsy is garaged, under her cover waitig for the newxt autocross season to start...
Need to deal with the tires situation but it will be in a few months
Super Coop
Aug 17, 2015 05:09 PM
Aug 13, 2015 12:57 PM
Aug 13, 2015 12:56 PM
Aug 12, 2015 01:24 PM
