Finding build date
Old Apr 29, 2007 | 02:17 PM
Jpolson's Avatar
Jpolson
Finding build date
Hey I bought a new car off a dealers lot and I am wondering how you could go about finding the build date? It is a 06 cooper
thanks
james
Old Apr 29, 2007 | 02:53 PM
ygblat's Avatar
ygblat
Try calling 866-ask-mini and tell them your VIN. I think they might be able to help. Congrats on your purchase, by the way!
Old Apr 29, 2007 | 03:00 PM
Frisco's Avatar
Frisco
build date.
Drivers door post shows that on data plate.
F.
Jeremy1026's Avatar
Jeremy1026
Moderator
Look at your drivers side door jam. There is a plate there, it should have "xx/xxxx" on it, thats your build date.
Old Apr 29, 2007 | 06:02 PM
Jpolson's Avatar
Jpolson
sweet, thanks guys, is there a build date for 06 coopers I should be worry about?
Old Apr 29, 2007 | 06:18 PM
Jeremy1026's Avatar
Jeremy1026
Moderator
Not really...all the 06's have the same quirkyness for the most part.
Old Apr 29, 2007 | 07:57 PM
cristo's Avatar
cristo
Alliance Member
You can also get the build week off of your odometer
Look at this link (under 1.4):
http://www.mini2.com/forum/draft-f-q...l-display.html
Old Apr 29, 2007 | 08:43 PM
Jpolson's Avatar
Jpolson
I found it, 11/06 so it was one of the last 06 of the line?
Old Apr 30, 2007 | 12:19 PM
gci's Avatar
gci
Mine was also built in 11/06! :tumbsup:
Old Apr 30, 2007 | 02:51 PM
Jpolson's Avatar
Jpolson
what color is yours? coopr or S? i have pics in my gallery
Old Apr 30, 2007 | 03:03 PM
ScottRiqui's Avatar
ScottRiqui
Since you have a November 2006 car, there is one thing that you should be aware of. Your car has the larger 14mm X 1.25mm lug bolts, not the older 12mm X 1.5mm bolts. This is going to become significant if you switch to aftermarket wheels, since many of them don't have bolt holes large enough to accept the 14mm bolts.
Also, even though the lug bolt change happened in July 2006, the owner's manual wasn't updated with the new torque values, and still lists a torque speciication of 88 lbf-ft. The bolts on your car are the same as the bolts in the new R56, so you should probably use the same torque spec as the R56 (102 lbf-ft).
Old Apr 30, 2007 | 07:48 PM
Jpolson's Avatar
Jpolson
So my car will fit the new 07 rims?
Old Apr 30, 2007 | 08:33 PM
ScottRiqui's Avatar
ScottRiqui
Yes - all of the factory rims will fit either the 12mm or 14mm bolts.
Old Jan 26, 2019 | 01:22 PM
scubus's Avatar
scubus
Never mind...
Gil-galad
Eastern Iowa MINIs
63
Nov 17, 2016 02:54 PM
David.R53
Sep 1, 2015 06:51 PM
Ovrclck
Aug 27, 2015 07:58 PM
PrimePower
Aug 11, 2015 12:51 PM
marendt428
Aug 8, 2015 04:44 AM
