Spark Plug Gap Setting
Old Feb 1, 2023 | 11:01 AM
Shaun 03's Avatar
Shaun 03
Have to change the coils on my R61 Paceman 2014 so doing the plugs as well! I can’t find what gap to set them too. They come set at 0.8mm standard!
Anybody any tips on Coil or Plug changes ?
Cheers
Old Feb 1, 2023 | 11:45 AM
Hello, here you go, check the N18 so its 2011+ Cooper S
https://www.northamericanmotoring.co...-plug-gap.html
Links to the socket you need if you have the 12 point like most plugs unless you get brisk plugs which take a standard 6 point socket.
Coils i run the Bavauto ones we carry. Just lift up and snap out on the coils. then insert and push down. They have a little tab on the top that slides in/out and you more the plug in/out. Kind of like a ECU connection.
https://www.ecstuning.com/b-bavarian...coil/5005~bav/
Old Feb 5, 2023 | 07:51 AM
Shaun 03's Avatar
Shaun 03
Update
Had issue with flat spot and misfire in 2014 Paceman Auto that was giving Gear selector code issues.
Sourced coils and plugs but decided to change 1 thing at a time ! Plugs first . Car running like a dream ! The gearbox expert I spoke to said the Misfire could cause code issues and he was right!
Thanks for the help.
Old Feb 6, 2023 | 07:41 AM
Welcome!
rustyeuro
15
Aug 25, 2022 01:27 PM
cyberlunacy
Aug 22, 2022 05:36 AM
DrkSilver163
Apr 4, 2005 08:11 PM
DrkSilver163
Electrical
Apr 4, 2005 07:49 PM
antsmini
Apr 24, 2003 03:15 PM
