Door handle woes
Old Feb 9, 2022 | 11:52 AM
MervCarr's Avatar
MervCarr
Door handle woes
Hi all
Can anyone perhaps tell me when MINI switched door handles from the 'squeeze' type handle to a 'pull out' handle? My wife is becoming increasingly frail due to illness and is having great difficulty squeezing her driver door handle on her 2012 Countryman S, sometimes reverting to holding the unlock button to roll the windows down so as to access the inside door handle.
I took a newer Cooper S 3 door for a drive a few weeks ago and was surprised to fing tyhe door handle design had changed to a 'pull out' type design. Way easier for her to open.
Old Feb 9, 2022 | 12:20 PM
chrunck's Avatar
chrunck
2014 for the hard top, 2018 for the F60 Countryman. I don't know the others off the top of my head.
Old Feb 9, 2022 | 12:42 PM
MervCarr's Avatar
MervCarr
Thanks, the 3 door S I took for a drive was a 2016
Old Feb 10, 2022 | 11:44 AM
Yep 2014+ that was the big change,.
Old Feb 11, 2022 | 06:09 AM
MervCarr's Avatar
MervCarr
Thanks for the info guys, now, next question, is it possible to convert from the squeeze to the pull type?
Old Feb 11, 2022 | 08:12 AM
Nope. If you have the squeezer type , use a little wd40 and spray in the joint at the pivot of the handle and grease/spray in the lock itself. This will help it work like when it was new, These handles/lock gum up over time.
Old Feb 11, 2022 | 08:58 AM
maccoder's Avatar
maccoder
This should help for sure. I did that a while ago and handles became a bit smoother.
But nothing you do will bring it to the same level as gen 3 handles/locks. I wish my car had such soft door close/open ever since having gen 3 as a rental for a day while mine was in for service.
Old Feb 11, 2022 | 09:13 AM
Here is the gen 1 MINIs https://www.northamericanmotoring.co...wont-open.html
Here is the Gen 2 MINI: https://www.northamericanmotoring.co...le-sticks.html
ItalianJobR53
Feb 1, 2018 07:51 PM
G$-Cooper-JCW
Sep 7, 2014 08:05 PM
CM51
R60/R61 Stock Problems/Issues
25
Mar 20, 2012 08:07 AM
Paul
Mar 12, 2006 08:00 PM
