2012 R56 started hesitating when accelerating but only (so far) on highway
Old Aug 26, 2021 | 07:04 PM
mark941122's Avatar
mark941122
The hesitation has thus far only happened on the highway, when times I needed a bit more power. For example going up a hill, keeping the same speed...or today I was merging and a car wouldn't let me in so I took my foot off the gas, then when I went back to gas it in made this hesitation again.
I did some research and found this hesitation could be several things. I checked the air filter, took out and cleaned the MAFS, (I've had new spark plugs & coils put in recently also)...so now should I suspect fuel pump? Is that the same as the High Pressure Fuel Pump (is there just one?)
For 2 years at cold start the car takes 30 seconds to warm up, if you try to move instantly it will stall. My mini specialist thinks this could be the HPFP going bad...(but 2 years?) and now I wonder if this hesitation is another sign?
Thanks to anyone who can help!
austin0423
Aug 18, 2021 02:39 AM
roromini07
Aug 22, 2019 06:08 PM
DDM12
Jan 12, 2018 06:32 AM
AlvaSpeed
May 21, 2017 05:16 PM
TheBigNewt
Dec 30, 2008 07:10 PM
