Manage your F-series Mini with your iPhone
Awhile ago, I wrote some iOS shortcuts to manage your F-series Mini with Siri on your iPhone. Sorry Android people, I got nothin' for you
Anyway, everything broke, but I think I just got it working again. I believe the only dependency is a working Mini Connected subscription, an iPhone, the Shortcuts app, and apple iCloud Drive.
How to use
Open the “Connected_setup” shortcut (do not run it)
* Click on the 3 dots next to the shortcut name
* Select "Customize Shortcut". Fill in the appropriate bits
Once thats done, run the "Connected_setup" shortcut. It should create a file called "bmw_connected.json" on your iCloud Drive.
Don't worry if you mess up the setup, you can just run it again. Also, please note, the shortcuts are kinda geared toward a GP (its what I have). You can modify them for your car (JCW, Mini, whatever) but thats on you to do. Also, you can't use a key phrase of "car" for some reason.
Also, I haven't been able to test this if you have a security question for Connected services, or for anything outside the USA. So...feedback is more than welcome! And you need all the shortcuts.
Setup the json file
Read the json file
Authenticate and get tokens
Get the locked/unlocked status
Lock your mini
Unlock your mini
Vent your mini
Edit: I had to update the "Setup" shortcut to work properly. If you already downloaded, please re-download. Sorry
How to use
Setup the json file
Read the json file
Lock your mini
Unlock your mini
Vent your mini
effkay
Oct 21, 2012 07:20 AM
Navigation & Audio Foursquare Iphone and MINI connected
TomLINY
Sep 10, 2012 08:24 AM
