How to remove jack blocks?.
Old Feb 22, 2020 | 12:13 PM
Jason Cornelius's Avatar
Jason Cornelius
So I had new tires installed at pep boys last Monday and I installed my new intercooler today so needed to jack up the car. Crawled underneath and there jack block in my passenger front side jack point and my drivers side rear. I know this guy forgot to double check and see if they were on his lift pads. I didn’t want to screw anything up by just going to town prying them out and I did grab on an give em a good wiggle bit they are in there.
Old Mar 9, 2020 | 10:39 AM
98oilhead's Avatar
98oilhead
Ther's a "pin" in the center of the jack block , that when you install the blocks the "pin" is pushed up into the block spreading apart some "fingers" that lock the block in place. You can pry the pins down and out to release the block from the car. Might be easier said than done
Old Mar 9, 2020 | 10:41 AM
Jason Cornelius
thank you, will take a peek after work.
Old Mar 9, 2020 | 01:37 PM
Capt_bj's Avatar
Capt_bj
Helps ... maybe? The 'center pin' spreads the tabs you see here ... pulling the pin 'up' releases the pressure on the tabs but may not release them entirely depending on age .... but a trim tool can solve this . . . You can see what you are working with . . . essentially a snap in part.
https://www.outmotoring.com/jacking-...rs-safety.html
Old Mar 10, 2020 | 07:31 AM
Andy_S's Avatar
Andy_S
Are these not a standard part of the car? My used R52 S came with four installed and they're still on there.
Old Mar 10, 2020 | 07:34 AM
Jason Cornelius
I know that they weren't on there before my tire change. I have read threads of them missing, so i wanted to take them off and not take a chance of blowing a tire.
Old Mar 10, 2020 | 01:05 PM
98oilhead's Avatar
98oilhead
These should be left on or if they're not there get some and put them on. These are installed so that you have a place to use the jack that came with the car. If you look at the jack/pad arrangement its pretty clear they are ment to work together it also provides a place for service dept. to place the lifting arms on a hydraulic lift
Old Mar 10, 2020 | 01:12 PM
Jason Cornelius
I’m not worried about jacking the car up, I have had it 4 months and have had it on jack stands, just one corner jacked up, up on hydraulic lifts, which I personally know my mechanic and wife went to school with him so I’m not worried there. PepBoys left one on drivers rear and one passenger front, so I want to take them off and use them when need if at all. I just don’t want to run one of them over when they decide they want to come off.
Old Mar 10, 2020 | 01:16 PM
98oilhead's Avatar
98oilhead
Well, as to falling off...if they're installed correctly they wont "fall off" speaking as someone with 60k plus since installing and being plastic I don't think you could blow a tire(I may live to eat these words).
Old Mar 10, 2020 | 01:36 PM
Capt_bj's Avatar
Capt_bj
PEP Boys didn't put them on and forget to remove. The car comes from the factory with these, permanently attached. More common is a garage beaks 'em and they fall off which is most likely what happened to two of yours. A GRRRRRR item when you find your garage busted yours.
there used to be someone selling aluminum replacements - harder to break ..... and if you want to remove all, go for it. They serve to protect the plastic rocker trim which gets in the way when you try to jack at the pinch weld.
Old Mar 10, 2020 | 01:48 PM
Jason Cornelius
Originally Posted by Capt_bj
PEP Boys didn't put them on and forget to remove. The car comes from the factory with these. More common is a garage beaks 'em and they fall off which is most likely what happened to two of yours. I GRRRRRR item when you find your garage busted yours.
I’m know PepBoys left them there, when I deleted the turbo muffler, there was nothing there on drivers side, just the holes where they go. When I had car in for clutch replacement I helped mechanic put car on lift and in know nothing was there on passenger side. When I did my intercooler, that is when I noticed them there, which was the same week I got tires from PepBoys. I wrench on this car, I know it sounds weird but after 4 months if there is something wrong or has been added, I will know. I have washed 11 years of dirt off of every surface , regularly check oil, all hose clamps, etc. Hell I checked the torque on my spark plugs after 2 weekends on the Dragon, plugs 2 and 3 were loose when I changed them, so a double check never hurts.
Old Mar 10, 2020 | 03:12 PM
Capt_bj's Avatar
Capt_bj
OK cowboy .....
Old Mar 10, 2020 | 08:24 PM
3Pedal's Avatar
3Pedal
I just got my MINI, I have the Detroit Tuned F54 jack which fits perfect in the block and I also have a massive 3-ton Harbor Freight Daytona floor jack. I didn't lift it all they way but I was curious if I can also use a floor jack saddle right on the rubber blocks as they are and lift or is there a better place to put the saddle ?
Old Mar 11, 2020 | 05:59 AM
Jason Cornelius
I personally would line that jack up straight in. Since I have 2 blocks I line my cup up with them. For the other 2 depends on what I’m doing. 2x4 in different lengths depending if whole side or just a corner, has worked for me for years and I’m comfortable with it. I switched out my mini jack for a much beefier scissor style the I’m also comfortable using.
Old Apr 19, 2020 | 04:58 AM
colinmini's Avatar
colinmini
I know this is an old thread but here are the short aluminum replacement jack pads!
http://waymotorworks.com/tsw-short-jack-points.html
Old Apr 19, 2020 | 05:02 AM
Jason Cornelius
I might actually swap to those, still have the 2 in and 2 missing, haven’t had a reason to jack up the car, oil change is coming up though.
Old Apr 19, 2020 | 09:40 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
I recently had one of my jack pads go missing, and I replaced all four with a set of these:
https://www.ecstuning.com/b-jl-germa...718268885~jlg/
Shorter than whatever was on my car, and plugged right in.
Old Apr 20, 2020 | 01:11 AM
3Pedal's Avatar
3Pedal
Thanks for posting, I'm going to get a set of these, good video on how these are installed and how to get the old ones off -
johntotah94
May 11, 2013 08:40 AM
BluMini9
Mar 22, 2009 03:26 PM
Bhatch
54
Oct 26, 2008 03:06 PM
2fast2
Nov 27, 2006 02:05 PM
blalor
Tires, Wheels, & Brakes
Aug 12, 2005 02:46 PM
