Looking to buy my first mini. Need help
Old Apr 27, 2018 | 10:21 PM
  #26
DamnCampers's Avatar
DamnCampers
Originally Posted by TRAVR6
Thanks for the info.
Picked up a 2006 S model yesterday. Time to do a bunch of research on preventative maintenance must do's /mods/ etc....
How many miles on the car? Any exisiting mods done to car that were communicated to you?
Old Apr 28, 2018 | 05:09 AM
  #27
TRAVR6's Avatar
TRAVR6
118,000 for $3500
It has an aftermarket intake.
No known mods other than that.
It has had some suspension work recently but I think it was just oem replacement parts.
Bought it about an hour south of Tampa, FL and drove it to Indiana in 2 days.
Drove fine. Just needs a little TLC
2006 R53 S model Manual
Old Apr 28, 2018 | 06:57 AM
  #28
bratling's Avatar
bratling
Super Moderator
118,000 for $3500
And it’s beautiful, too! 😍🏎💨
I do enjoy my 2015 but the R53 remains the absolute most engaging and visceral to drive. I’m positive you’ll love it!
Old Apr 28, 2018 | 01:41 PM
  #29
TRAVR6's Avatar
TRAVR6
It has had the 100,000 service done by Mini.
Tie rods, A arms, Brakes/rotors, clutch at 90K.
It has an oil pan gasket leak but other than that, no major issues.
Old Apr 28, 2018 | 02:26 PM
  #30
DamnCampers
Has the harmonic balancer been replaced? Its a common OEM item that fails often and unpredictably.
Old Apr 28, 2018 | 02:36 PM
  #31
TRAVR6's Avatar
TRAVR6
m
Not that I know of. I am going to contact the dealership on monday to see if they will give me the service records.
Old Apr 28, 2018 | 02:37 PM
  #32
TRAVR6's Avatar
TRAVR6
The wheels are curbed to death. I may try to repair them if I can't find a cheaper set.
Old Apr 28, 2018 | 03:09 PM
  #33
DamnCampers
Check thru the mini owner's lounge to see if there any service records if you don't want to talk to the dealer. Any work that has been preformed by a dealer on my car appears there last time i checked.
Old Apr 28, 2018 | 03:25 PM
  #34
TRAVR6's Avatar
TRAVR6
Just registered and checked. Nothing in there since 2006.
Old Apr 28, 2018 | 05:40 PM
  #35
AZdsrt's Avatar
AZdsrt
Google "wheel repair". Lots of places refurbish them, usually much cheaper than replacing them.
Old Apr 28, 2018 | 06:10 PM
  #36
TRAVR6's Avatar
TRAVR6
I can do it myself for free. Well the cost of materials.
Just never seen a wheel with "Thick" paint like this.
Old Aug 19, 2022 | 05:09 AM
  #37
Planewizard's Avatar
Planewizard
2006 “S” model Oxy sensor heater wiring
Hi; I’m new to Minis. Just picked up a 2006 R53 convertible with high miles, but running good, except get P0053 code (upstream 02 sensor heater fail).
PO changed two of them, so doubtful the unit-failure is the issue.
I understand the two black wires may be the heater circuit for the sensor???
I got a useless online Haynes manual, which doesn’t have detailed enough wiring info.
can someone point me in the direction of a good wiring diagram for a 2006 S series?
thanks
Old Aug 20, 2022 | 10:53 AM
  #38
Planewizard
Need help finding O2 heater relay plz…
Previous owner changed two O2 sensors (upstream). Still getting P0053 code.
it’s in the heater circuit. I don’t believe it to be “sensor” portion that is bad because it only comes on when car is cold. If I cleared previous check engine light and start when cold, after two or so miles, I get the warning light.
At engine operating temp, if I clear the code and keep driving, the check engine light DOES NOT come on again.
this makes sense because the sensor really doesn’t need to be heated when hot; only when first starting.
I drove about 30 miles this way with no more light.
let it sit overnight, and it comes up again, until cleared (and hot). I suspect the upstream, O2 sensor relay is bad.
DOES ANYONE KNOW WHERE THAT RELAY IS LOCATED???
Diablo243
R55 :: Clubman Talk (2008+)
Jul 29, 2014 06:22 AM
foxxinsox
Apr 17, 2012 08:50 PM
ddawson
Jul 23, 2008 06:08 PM
Screamer
Jun 26, 2007 02:30 PM
WannabeMCS
Jun 18, 2003 08:47 PM
