R53 Driver door lock
Old Jan 26, 2017 | 12:40 PM
CHILLI.T's Avatar
CHILLI.T
Purchased 2 weeks ago and immediately discovered the keys will unlock the door manually but not via the button. It unlocks everything else just fine. Any simple fix?
Old Feb 2, 2017 | 05:21 AM
Derek86's Avatar
Derek86
Could be a dead battery.
https://www.northamericanmotoring.co...ob-repair.html
Old Feb 2, 2017 | 10:44 AM
+1 check the battery first. Then sure you are in range, the gen 1 MINIs dont have a far range. Then check the fuses and the receiver which is located in the rear view mirror.
Old Feb 2, 2017 | 01:09 PM
nkfry's Avatar
nkfry
As in the key unlocks the passenger door and boot electronically, but not the drivers door?
If so the most likely culprit is a drivers door lock actuator, second to that could be a BCM problem.
Phone:586-792-6464
Info@DetroitTuned.com
Nick@DetroitTuned.com
Old Feb 11, 2017 | 07:48 PM
Dallas_MINI's Avatar
Dallas_MINI
when i bought mine it had the same issue. drivers door would lock electronically but only unlock with the key. it was def my door lock actuator. there's some great write ups about fixing it yourself. i followed the directions and mine now works great.
