Which recommended maintenance is crucial?
Old Mar 29, 2016 | 04:45 PM
martin122089's Avatar
martin122089
Hi all! I apologize if this isn't the right forum for this question, but I figured it was pretty general in nature so I was in the right place .
I am wondering which of the recommended maintenance suggested by my dealer is actually crucial for me to do. I get my oil changed every 7500 miles, but that's about it as far as regular maintenance goes for me. I see on the dealer website there is a 66,000 mile list of services that includes:
-brake fluid
-coolant flush
-engine oil
-front brakes
-intake silencer
-microfilter
-rear brakes
-roadworthiness test
-spark plugs
-vehicle check
Do I need to get all of these done to my car as often as the dealer suggests? My car is an automatic 2011 MINI Clubman S with around 61000 miles on it that I have owned for 2 years (since around 32000 miles).
As far as I know it has never had any of these services done besides the engine oil every 7500 miles or so. I have asked the dealer multiple times about the brakes, but according to them I am still good.
Thanks in advance for any wisdom!
Old Mar 29, 2016 | 08:08 PM
mini4mo's Avatar
mini4mo
Originally Posted by martin122089
-brake fluid
-coolant flush
-engine oil
-front brakes
-intake silencer
-microfilter
-rear brakes
-spark plugs
-vehicle check
You can stretch these out as long as you want.Of course performance and safety should be considered.
I take my wifes 2012 in only for warranty work.
With about 53k on her's,I have done the following....
Change the oil about every 5K
Changed the cabin filter twice
Changed the plugs at 50K
Replaced the rear brakes when the warning appeared
Changed the brake fluid at about 3 years
Changed the coolant at 53k
I don't know anything about the intake silencer,maybe someone will chime in.
Old Mar 30, 2016 | 05:32 AM
AoxoMoxoA's Avatar
AoxoMoxoA
I am wondering which of the recommended maintenance suggested by my dealer is actually crucial for me to do...
All the items on your list can be labeled as "crucial" when the time comes to replace them. If you've kept up on your oil changes and the brakes are sound, and if I were to prioritize which service you should address next, it would be the coolant flush and spark plugs, both of which you can easily perform yourself with the DIYs available on this forum...
Old Mar 30, 2016 | 05:38 AM
Oil change, Brakes if they are worn down very low, but sounds like your are ok. Like all people said the crucial part is that you have all your MINI service up to date. Also comes down to time and if you can DIY, dont hold off too long as you might not have time and never get them done.
Old Mar 31, 2016 | 05:11 AM
mini4mo's Avatar
mini4mo
So what is the intake silencer and when to change it?
Old Mar 31, 2016 | 06:17 AM
Fly'n Brick's Avatar
Fly'n Brick
Serpentine belt.
Its that long skinny black thing you see lying on the pavement other people leave behind. You don't want to leave one behind.
Old Mar 31, 2016 | 07:48 AM
intake silencer = air filter or intake muffler is what the pasts diagrams call it.
Old Mar 31, 2016 | 08:01 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
there's test kits for coolant and testers for water in brake fluid
Old Apr 2, 2016 | 06:39 AM
mini4mo's Avatar
mini4mo
Strange name!
Old Apr 2, 2016 | 07:14 AM
cristo's Avatar
cristo
Alliance Member
Software update to the nut behind the wheel is essential in many cases.
This is a universal recommendation - not aimed at you in particular.
Old Apr 2, 2016 | 07:21 AM
Fly'n Brick
One of the most neglected service items.
Rons02JCW
Oct 21, 2016 01:08 PM
jmcveyster
Mar 6, 2016 08:25 PM
Jake Lee
Mar 1, 2016 06:24 PM
Braminator
Test Forum
Feb 22, 2016 06:43 PM
rchap
Feb 15, 2016 10:19 PM
