2004 Mini electrical problem refuses to start :(
Old Sep 29, 2015 | 05:02 PM
mni928's Avatar
mni928
Hi all, I bought this mini for cheap cause of the CVT (of course) but the previous owner was'nt using it much during the last months because of the tranny. So he had to jump start the car but he said that since he did that the mini don't start anymore. I bought it like that.
What I found is that when we try to start, the only thing we hear is the clic of the relay. I checked for the fuses and found fuse #41 burnt. I changed it and it did'nt burn again but the car won't try to start more. When we try to start it does like if the car was in R or D position or if we don't press the brake. Is there something else that I should do or forgot or don't know? Is a burnt ECU could do that?
Any help is welcome
Old Sep 29, 2015 | 06:41 PM
AZdsrt's Avatar
AZdsrt
Not trying to be snarky, but do know you have a known good battery in there? If it has a short in one of the cells, you might not be able to jump it.
Old Sep 29, 2015 | 07:04 PM
mni928's Avatar
mni928
Like I wrote, any help is welcome even if it makes me look stupid lol
I did'nt check the voltage since everything else works fine. Usually when a battery is bad everything drops when we try to start cause the starter motor drains all the current available. In my case I don't loose anything when starting and the starter makes no effort.
Are you telling me that the ECU does'nt allow the starter motor to work cause the battery does'nt give the right voltage?
Thank's for your help
Old Sep 30, 2015 | 02:12 PM
mni928's Avatar
mni928
Just to confirm what I tought, I just tried another battery that was certainly good and no difference :( I can't wait to hear the starter motor.
Old Sep 30, 2015 | 04:15 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Some good info in this thread here. The battery you used was a brand new one? I'm sure you have, but will say it anyways, check the grounding strap on the left side of motor for tightness. Have you tried to jump it with another car? Other thing I can think of is a starter issue maybe...
888.280.7799 | 6am - 5pm PST
Old Sep 30, 2015 | 05:49 PM
mni928's Avatar
mni928
Ok the test I made was to remove the mini's battery and put a more powerful brand new one for the test and nothing else happened. The clic I hear when I try to crank is just the clic of the relay under the dash not the clic coming from the stater or solenoid. This problem began when the previous owner tried to jump start the car. I bought it like that.
Old Oct 9, 2015 | 07:39 PM
mni928's Avatar
mni928
Does anyone have the pin out of the ECM ?? I would like to trouble shhot the startting problem and follow and confirm each possibility like the proximity switch or detector on the brake pedal. I doubt we can fin this in any repair manual :(
Old Nov 9, 2015 | 07:38 PM
mni928's Avatar
mni928
Just to close this thread if ever it can help someone else. 2 months later I found my problem. The time my pit was available to work under and the time I receive the right parts (4 in a row defective or not the right one :( )
It was the short copper braid cable between the solenoid and the starter who was completely desintegrated. I could'nt hear the sound of the solenoid when I was trying to start.
Of course I had to change the starter assy and every thing is fine now.
Thank's for the help
iggi
18
Feb 9, 2026 01:00 AM
09R56
Nov 16, 2022 10:49 AM
Svejk
Feb 24, 2019 12:18 PM
bc219
Aug 10, 2015 11:22 AM
