how to lift this car?
Old Jun 18, 2015 | 08:07 PM
vroom747's Avatar
vroom747
hi all
just wondering the best way to lift this little car using only two candle Under lift point.
Do I ve to remove the piece of black plastic Under the car (at lift point) those work well with the jack that come with the car.
any link or advice are welcome!!! picture
thanks
vroom747
Old Jun 18, 2015 | 08:26 PM
05r50's Avatar
05r50
The service jack works fine with the stock lift points. But if you want to use a floor jack, then this helps. http://www.outmotoring.com/mini-coop...ad_spacer.html
Old Jun 19, 2015 | 12:09 PM
Slave to Felines's Avatar
Slave to Felines
I hate the service jack. The one time I tried to use it, it failed to lift the car and it leaned over and damaged the rocker panel on the car. I think it's a total piece of rubbish, especially as it relies on not being able to slide on the ground in order to do its work. Yeah, no.
I bought a used scissors-type jack out of an old Honda or some such, and keep it in the car now. I'm not using the stock POS jack again.
Old Jun 19, 2015 | 01:05 PM
3lusive's Avatar
3lusive
I've used the scissor type jack that comes with the car multiple times with no issues. It lifts the car barely high enough to slip a jack stand underneath but i haven't had it slip on the ground at all.
Old Jun 19, 2015 | 04:32 PM
dongood's Avatar
dongood
There is the 2x4 method.
Cut a length of 2x4 to run between the two jack points.
Place the 2x4 along the lip and running between the two jack points, use a floor jack, placed middle of the 2x4, to lift the car.
Place jack stand at the jack points, repeat on the other side
Search this forum for more info including a link to a step by step with photos.
Edit:
Google is your friend.
Old Jun 19, 2015 | 05:53 PM
TJANK's Avatar
TJANK
I read about simply using a hockey puck placed on top of the floor jack. I tried it and it works great to provide enough clearance on the lift points.
honderpilot
Aug 31, 2015 02:53 AM
kpl
Aug 11, 2015 04:52 AM
ludedude
Aug 10, 2015 07:16 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
PatrikKN
Aug 5, 2015 09:10 PM
